Question about Audiovox AVT-1475 13" TV
Vertical hold on tv
Can you adjust the vertical hold with the remote? There is no vertical hold knob on the TV. The picture goes back and forth from fine to rolling up and down rapidly. Thanks so much! It's a Mitsubishi CS-27EX1 from 1993.
  • pegmeister Mar 25, 2009
    When turned on, the picture rolls continuously and I don't know how to stop it.
  • fuman2vw May 11, 2010
    how do you stop the the picture to stop rolling
    Novelist:
    Champion:
  • 236 Answers
No control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
Posted on Apr 07, 2008
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
The picture on My Zenith TV is not centered. How can I fix it?
there are adjustment knobs located on the pcb for the horizonal and vertical holds. try adjusting these to fix your problem.
Aug 08, 2010 | Zenith C36V23 36" TV
Picture has reduced to a fine horizontal line in the center of tv
It sounds like your vertical driver for the tv tube is burned out. you can try to adjust the picture settings with your remote. If it is an older tv there may be knobs on the tv set itself to adjust your brightness/contrast/ etc. there may be a picture size adjustment some where. But I feel that you will need to take it to a repair shop. In a lot of cases the repair bill is more expensive than going out and buying a new tv. Also check to see if your warantee is up, and check online for your brand and model of tv on the manufactures website to see if there was a recall.
hope this helps
Aug 08, 2009 | Durabrand DWT2704 TV
I cannot find vertical hold
The sync is automatic. There are no knobs to turn. If the picture is rolling, look first to the source connection and make sure your tv has a solid vertical sync connection. If you are using the RF input then the issue could be within your small signal board also known as the SSB. Good luck.
Mar 23, 2009 | Televison & Video
Mitsubishi CK-3526R TV
not sure what light picture has to do with problem  but no there is no  vertical hold control  prob bad electrolytics invertical feed back circuit, need tech..
Dec 07, 2008 | Mitsubishi WS-55807 TV
No picture but sound ontv
first adjust the screen knob at the back of the plyback and then check the screen ,if you see a vertical line ,then vertical IC is busted or else lose connection.
Sep 14, 2008 | Sanyo HT32744 32" TV
Jumpy / Schrolling Picture...?
this is a problem of synchronization.  are there any adjusting knobs in the tv set (vertical hold adjust) if  yes you can try but if none maybe consult a technician.
Oct 30, 2007 | Akai PT5492S 54" Rear Projection...
Bottom of picture is not all the way visible.
you need to adjust the vertical setting on your tv set. are you a tech person? if you are just follow these instructions. turn the tv off and unplug it. take the back of the tv off. you will find the screen and the crt tube. on the tube, you will find the yoke of the screen follow the four wires coming down to the board. you will find small knobs. you will find writing next to these knobs. look for vertical phase. once you find it. now you have to plug the tv and do this live. be carefull. once you see the picture on the screen. adjust this knob till you see the bottom. good luck
Apr 17, 2007 | Orion STV2763 27" TV
Audiovox AVT-1475 13" TV Logo
884 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
