Question about GE Energy Star WCVH6260F Front Load Washer
GE WASHING MACHINE GE PROFILE
WHAT DO I DO TO GET RID OF THE MILDEW SMELL? PLEASE HELP
  • frustatedmom Apr 10, 2008
    I am having the same problem. My machine is less than 6 months old, but smells like mildew! What can be done to resolve this issue?
  • rvman Apr 18, 2008
    Had the same problem after machine was a year old. You need to remove panel below door by removing 3 screws. You will see a white drain plug, aprox 2 1/2" in diameter. Place bucket under drain plug and unscrew and pull out, you will be amazed at all the stuff this drain lug can trap. It also traps water and machine will not fully drain and will give off a very bad odor. If to much gets trapped and clothes seem to be wet at the end of a cycle this is your problem and puts the water pump at risk of failure. It cost me several hundred dollars to find this out from the GE service tech who replaced my pump and said this should be done every 6 months to prevent problem. Checked owners manual and found no mention of such maintenance that home owner has to do, but we did it again 6 months later and it was starting to plug again. My sister-in-law had same problem within 5 months and GE cover it under warranty. By the way we purchased all GE appliances because she is a GE employee. It has been 6 months since this repair and now we are leaking water from under the drum during the spin cycle. Any suggestions? This is getting old for less than 2 year old machines. The last set of washer and dryers I purchase lasted 15 years with no problems and we paid far less than the premium we paid for these GE front loads and as far as we know they are still trouble free as we sold them with our last home. It seems that GE is trying to generate service business by building in customer maintenance requirements that the consumer is not aware that they need to do.
Occasionally have had a mildew smell with my washer too, but hadn't tried opening the drain plug. I discovered one penny, very little lint, enough water to half-fill a 9x13 baking dish, pretty clean looking. We've had our washer for over two years. Why don't I have a problem here? Hmmm...Here's my two bits:
Fully unload pants pockets before washing: pencils, coins, but especially Kleenex! Zip zippers closed, hook bras closed. Don't overpack the washer or it doesn't rinse that well. (These suggestions are for reducing lint & objects in the drain, also keeping your clothes from getting ripped up). Since I always do this, maybe that's why I don't get the buildup in the first place (or the ripping mentioned in another place on Fixya).
After each washing--"Appliance Brainiac" mentions this too--open up the folded area of gray rubber at the bottom of the door opening (fold the flap back toward you) and wipe it down with a rag--an old washcloth kept in the laundry room for that purpose, for instance. This area also accumulates water, plus you can tell if you're using too much soap if there are ANY suds there. As "Guest" noted, you can also pull back the second layer of rubber and clean up those small drain holes too, as they will accumulate some guck in the long run. Maybe my doing this regularly kept another mildew culprit at bay, plus it also taught me how to gauge how much soap was too much.
After each washing, I also wipe down the glass so I don't have any water spots, AND I LEAVE THE DOOR OPEN for 24 hours so the washer can air out. If I close it, I do get the mildew smell.
For you with mildew, the above are preventive steps for the future. For killing existing mildew, Appliance Brainiac seems to have hit it on the head with Affresh. I'd have tried running an empty load with Clorox bleach, but--I never have so I can't suggest that it actually works.
Last note--I live in the desert, so I don't expect mildew. If you live in, say, Florida, you're going to have to be really aggressive with the standing water that does indeed sit in places in the machine--wipe downs and regular treatments, the occasional draining. Good luck, hope this was helpful--GrannyWrench
Posted on Jul 01, 2008
I've had my GE WCVH6260F washer for 20 months and my clothes began coming out of the washer with lint lines on them. I took the advice of "rvman" and took the panel off of the washer below the door and opened the white drain plug. To my surprise I found 4 short pencils, 3 quarters and a small amount of lint in the trap. I also pulled back the rubber liner at the bottom of the tub and found that all of the drainage holes were clogged with lint. I took a bobby pin and cleaned out the small holes and used a very small brush to pull out the lint from the bottom-most drainage hole. I no longer have standing water and the mildew smell has subsided. I wish the manufacturer would include these simple fixes in their manual. Thank you rvman for saving me a service call.
Posted on Jun 18, 2008
There is a product out there called Affresh. It is a tablet that can be used on all front loaders that do not have a Clean Cycle. It works great. It comes three tables to a bag. You should use all three the first time that you do this. After that, once a month is all that is needed. Two suggestions to help eliminate the smell and mildew. One, keep a wash rag handy and wipe up any water that remains in the door seal. Second, leave the door open for a day so that the washer can air out. This applies to all front loaders, not just GE, that do not have a Clean Cycle. Also, water sometimes stays in between the inner and outer tub. This water can become stagnant and create mildew, mold, and odor problems. I hope this helps!!! -The Appliance Braniac
Posted on Apr 15, 2008
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
How do i get rid of the smell of mildew in my washing machine
There is a washing machine cleaner that is made to do that. Need to use is about monthly...The issue is universal and physics based, but the cleaner works well.
May 01, 2011 | Kenmore Front Load Washer
The inside of my maytag epic front loader washing machine smells like mildew. how do i get rid of the smell? its making the clothing smell bad too.
Buy some Affresh cleaner. You can find this at Home Depot. It should clean gookus from front boot. Also, take a dry rag and `clean the boot area of mold and mildew. I know some of my customers just leave the door open overnight to let it air our.
Sep 26, 2010 | Maytag EPIC MFW9700S Front Load Washer
How do i get rid of the moldy smell?
Here is a tip that will help you with that...
Stop Washing Machine Smell, Mold, and Mildew
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
heatman101
May 30, 2010 | LG WM2455 Front Load Washer
What can ido to get rid of musty smell
Here is a tip that I wrote about that...
heatman101
May 19, 2010 | Hotpoint WMA40 Front Load Washer
How do I get rid of mildew smell in Siemens UltraSense front-load
Siemens
WFXD8400UC Front Load Washer
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 17, 2010 | Siemens WFXD8400UC Front Load Washer
My washing machine smells like mildew or mold - how can I get rid of this smell
you can take 100ml of vinegar which is used for cooking to be filled in machine then if your machine have heater option please turn on the heater to 65 degree and start the machine for the normal process all dust particle will be removed and you can see the cloth washing quality will be very high
Dec 23, 2009 | Washing Machines
Hi, I have a hoover front loading washing machine and inside the drum seal there was a lot of mildew as I accidentally left some damp tea cloths inside the drum and the machine wasn't used for 2 weeks....
Run your washer with 2 cups of bleach, maximum hot water. After it starts agitating for a minute, stop the washer & let it remain for 2 hours. Then continue the wash.
Apr 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Mildew smell
Try doing just a hot bleach water "load".  Also check underneath and around the machine to make sure it's not leaking.  If it did or is and you can see the mildew just spray it with bleach.
Oct 11, 2007 | LG WM-2277HW Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
833 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
