Question about Evenflo Triumph 5
Remove Seat to Wash
How do I remove the car seat cushion to wash it?
  • engelfamily9 Apr 16, 2009
    The Evenflo Triumph car seat almost lets you remove it to take it off, but the velcro doesn't continue far enough to get the whole thing off. That would neccesitate taking the belt system apart in some way or cutting the carseat cover to get it off. Help!
I still had my manual and it said to unscrew the back; and you do have to take out the top of the straps to get the pad off. I just did this last weekend and then re-install everything. It worked great! The only problem I found was that when the pad is washed, the pad backing gets caught in the velcro and needs to be removed.
Hope that helps!
Posted on Aug 28, 2009
How do i remove the cushion to wash this car seat
Posted on Aug 24, 2008
How do you remove the back seat to get to the fuel pump?
On what? 3 possible ways the rear seat cushion is removed. On some the seat has clips that lift straight up. Or some have 2 small bolts at front bottom of rear cushion. Remove the bolts and seat slides out easily. The final way is old style: a heavy wire on bottom of cushion, one on each side, fits into slots that come up from the frame underneath. To remove, push cushion hard to the rear until the heavy wires can be removed (lifted up) from the slots. Do one side at a time. These are the most difficult to remove the rear bottom cushion. You have to push hard against the cushion near the bottom of it, pushing it backwards, so the wire comes out of the slot, and then cushion can be removed.
First try lifting straight up on the cushion. Since there is an access panel to the gas tank, it is very possible the cushion is easily removed by lifting straight up.
Jun 05, 2015 | Seat Cars & Trucks
Remove rear bench seat
I don't know about your exact make, but every bench rear seat bottom I ever messed with removed as follows:
Get your fingers under the bottom of the seat cushion, and give a sharp tug upwards.
It should be held in by spring clips, which will release with the upward tug.
With the front of the seat cushion slightly raised (so the spring clips can clear the brackets), it should then pull straight forward and out.
To re-install, push the cushion back under the seat back (with the front slightly raised), and with both hands, give a sharp push downwards to latch the spring clips.
Apr 24, 2014 | 1998 Nissan Pathfinder
How to remove bottom of back seat need to remove seat to remove rear shocks..
PUSH IN CENTER FRONT EDGE CUSHION TO DISENGAGE PART OF SEATS WIRE FRAME FROM CLIPS.WITH CLIPS UNHOOKED LIFT UP AND REMOVE SEAT.IF REAR SEAT NOT HELD IN PLACE WITH CLIPS. LIFT UP THE REAR SEAT CUSHION AND PIVOT IT FORWARD. DETACH THE RETAINING BOLTS AT THE LOWER EDGE OF THE SEAT BACK AND IF NECESSARY REMOVE THE SEAT BELT ANCHOR BOLTS.LIFT UP ON SEAT BACK REMOVE IT..
Feb 06, 2011 | Jaguar X-Type Cars & Trucks
Truck lock is jammed by briefcase strap. can i get into the trunk from the back seat? such as does the back seat fold down?
I searched the owner's manual and there was no mention of folding the rear seats down. If you don't have a manual, you can get one here: http://www.extendedgmwarranty.com/owners-manual/buick/1999-Buick-Century.pdf
You can remove the seats following the instructions below from autozone.com.
Rear Seats
SEAT CUSHION
Fig. Typical W-Body rear seat cushion removal
  1. Locate and remove the small bolts at the front lower edge of the seat cushion.
  2. Pull the tabs on the rear cushion retainers.
  3. Remove the seat cushion by lifting up and pulling out of the retainer.
  4. Installation is the reverse of the removal procedure. Make sure the retainer tabs are snapped into place. Tighten the bolts to 18 ft. lbs. (25 Nm).
SEAT BACK
Fig. Typical W-Body rear seat back removal
  1. Remove the seat cushion as described above.
  2. Remove the anchor nuts securing the rear seat retainer at the bottom of the seat back.
  3. Grasp the bottom of the seat back and swing upward to disengage the offsets on the upper frame bar from the hangers.
  4. Lift the seat back upwards to remove from the vehicle.
  5. Installation is the reverse of the removal process. Make sure the hooks on the seat back are properly installed to the hangers. Tighten the anchor nuts to 89 inch lbs. (10 Nm).
Nov 07, 2010 | 1999 Buick Century
How too remove back seat in a 1995 Nissan Maxima
Rear
See Figures 3, 4, 5 and 6
  1. Remove the lower seat cushion by pulling straight up on the front portion and disengaging the clips. Then hinge the seat upward to release the rear clips.
Fig. 3: Pull up on the front of the lower seat cushion and disengage the clips
  1. Remove upper rear seat back-to-chassis bolts.
Fig. 4: Remove the bolts behind the center armrest ...
Fig. 5: ... and the bolts on the lower corners ...
Fig. 6: ... Then pull up on the seat to disengage the three clips on the top of the seat
  1. Remove rear seat back by tilting forward and pulling straight up.
To install:
  1. Install the lower seat cushion and torque the lower rear seat-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm).
  2. Install the upper rear seat back cushion and torque the upper rear seat back-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm)
Hope help with this (remember rated this).
Jul 19, 2010 | 1995 Nissan Maxima
How do i remove the backseat in my thunderbird?
Rear Bench
(see Figure 4)
  1. Bearing down with your knee on the rear seat cushion, push the cushion rearward and disengage it from the retaining brackets.
  2. Remove the rear seat armrests if applicable.
Fig. 4: Pull the bottom of the seat upwards and pull out
  1. Remove the seatback lower retaining screws and seat belt bolts.
  2. Grasp the seatback at the bottom and lift it up to disengage the hanger wire from the retainer brackets.
To install:
  1. Position the seat back assembly so that the hanger wire is fully engaged in the package tray slots.
  2. Install the lower retaining screws and tighten to 13-19 ft. lbs. (17-37 Nm).
  3. Position the seat cushion assembly into the vehicle.
  4. Apply knee pressure to the lower portion of the seat cushion assembly. Push rearwards and down to lock the seat cushion into the seat retainer.
  5. Check the seat cushion to ensure it is secured into the floor retainer.
Rear, Fold-Down Seats
  1. Push the rear cushion rearwards, then lift to release. Remove the cushion.
  2. Remove the 2 lower retaining screws attaching the seat back to the floor.
  3. Lift up and disengage the upper clips of the seatback from the top of the folding floor.
  4. Remove the seat assembly.
To install:
  1. Position the seat back assembly and align the retaining hooks. Ensure hooks fully engage in slots.
  2. Install the two outboard retaining bolts, then tighten to 13-19 ft. lbs. (17-27 Nm).
  3. Lower the seat backs and install the upper retaining screws.
  4. Install the lower center retaining screw, tighten to 13-19 ft. lbs. (17-27 Nm).
  5. Install the rear seat cushion. Ensure the rear seat cushion front retainers latch properly.
Hope helps (remember rated this).
Jul 01, 2010 | 1994 Ford Thunderbird
How do you remove the rear seat of 2004 honda accord
Release the two latches at the front of the seat cushion (pull back on the latches to release the front of the cushion).
Remove the seat cushion bolt and remove the cushion (it’s roughly in the center. You have to insert a socket extension between the back and bottom seat cushions to take it out, after you find it by pressuring the bottom cushion and looking back in there).
Remove the bolts (each side) securing the seat side bolsters (they are easy to see once the bottom cushion is removed), then remove the side bolters (gently release the clips that hold them in).
Pull the seat forward, then remove the fasteners securing the seat hinge (seat pivot bracket) and remove the seat backs.
Hope this helps you.
Dec 10, 2009 | 2004 Honda Accord
I need to replace a rear seat belt in a 1997 Ford Tarsus. Does any know the best way to access the assembly? In addition, are there any diagrams available that show the connection points?
please don't forget to rate, thx.
Retractor and Tongue—Sedan
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Safety Belt Bolt Bit T77L-2100A
NOTE: Safety Belt Bolt Bit T77L-2100-A should be used for safety belt removal and installation.
Removal
  1. Remove rear seat cushion. Refer to Section 01-10 .
Seat Cushion, Rear Sedan
Removal
  1. Apply knee pressure to lower front portion of the rear seat cushion. Push rearward to disengage rear seat cushion pad and frame (600A88) from rear seat cushion front retainers (63370).
  1. Remove rear seat cushion from vehicle.
  1. Remove rear seat back. Refer to Section 01-10 .
Seat Back, Rear 60/40 Split Bench—Sedan
Removal
  1. NOTE: Safety belt bolts do not secure seat back to vehicle.
    Remove rear seat cushion as described.
  1. Fold down back seat and remove two bolts in the center of each seat back striker plates.
  1. Remove two bolts from outboard rear seat back frame retaining brackets.
  1. Lift seat back up and pull forward to remove from vehicle.
  1. Remove panel (52018) and quarter trim panel (31012). Refer to Section 01-05 .
Trim Panel, Quarter—Sedan Removal
  1. Remove rear seat. Refer to Section 01-10 .
  1. Pull up on rear section of rear door scuff plate that overlaps lower quarter trim panel.
  1. Pull lower quarter trim panel away from body.
  1. Remove safety belt retaining bolt.
  1. Feed safety belt through lower quarter trim panel.
  1. Remove safety belt anchor plate-to-sill bolt from quarter panel.
  1. Remove retractor anchor nut and retractor from rear quarter panel.
  1. Remove upper seat belt anchor bolt and anchor from upper rear quarter panel.
  1. Slide anchor plate end of safety belt through the openings in the quarter trim panel.
  1. Remove outboard front safety belt retractor and tongue (611B08) from the vehicle.
    Item Part Number Description 1 386277-S190 Bolt (Part of 611B68) 2 31012 Upper Rear Quarter Trim Panel 3 611B60 Retractor and Tongue 4 N800937-S190 Nut 5 389370-S190 Bolt 6 — Rear Quarter Panel (Part of Body) 7 52018 Lower Rear Quarter Trim Panel 8 — Mounting Stud (Part of Body)
  1. Remove seat belt anchor bolt and retractor and tongue from rear deck panel.
Installation
  1. To install, reverse Removal procedure.
  1. Make sure the safety belt webbing is not twisted. If it is, remove the twist.
  1. Tighten retractor anchor bolt and safety belt anchor plate-to-sill bolt to 34-46 Nm (25-33 lb-ft).
  1. Check the restraint system for proper operation.
Jun 30, 2009 | 1997 Ford Taurus
Mustang rear seat removal?
please rate highly if this is what you need
Section 01-10: Seats and Tracks 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Seat Cushion, Rear Removal and Installation
  1. Release pin from locks by pressing release button under rear seat cushion.
  1. Pull rear safety belt and buckle (60044) through openings in rear seat cushion pad and frame (600A88) and remove rear seat cushion pad and frame .
REMOVAL AND INSTALLATION Seat Back, Rear Sedan
Removal
  1. Remove rear seat cushion as outlined.
  1. Remove rear seat bolster. Refer to Section 01-05 .
  1. Remove rear seat bolster mounting bolts. Remove bolster assembly.
  2. Remove four seat back to package tray retaining bolts.
  1. Remove seat back.
May 04, 2009 | 2004 Ford Mustang
How to remove the back seat from my 1998 Mercury Villager
it is not designed to be removed. It is designed to slide back and forth as needed.
Section 01-10: Seats and Tracks 1998 Villager Workshop Manual
REMOVAL AND INSTALLATION Seat, Rear Bench
Removal
  1. Remove the center seat(s) if equipped. Refer to the procedure in this section.
  1. Slide the bench seat forward to the center row seating position.
  1. Use a flat-blade screwdriver to remove the cover caps from the front of the rear seat cushion latch cover.
  1. Remove the two rear seat bolts from the front of the rear seat cushion latch cover.
  1. Lift the rear seat cushion floor cover on the back of the rear bench seat and remove the two inboard rear seat bolts and the two outboard rear seat bolts.
  1. Remove the bench seat from the vehicle through the body side door opening.
Apr 30, 2009 | 1998 Mercury Villager
Evenflo Triumph 5 Logo
524 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
