Question about GE Profile Spectra JGBP90 Gas Kitchen Range
All the stove top ignitiers work intermitantly.
They spark sometimes and others they don't. I have tried cleaning everything I can think of including the screws that are used to ground the heads, but nothing fixes the problem. I'm guessing the control board may be the problem, is there a way to test it? Also if that is it where is the best place to get the part?
  • 5,911 Answers
If ALL the igniters are affected in the same way, I would suspect a spark module that is going bad. All the top igniters are the spark type and are fed by a spark module located either behind the bottom drawer or behind panel on the back of the range. carries the part for about $65. Just type in your COMPLETE model number in the Search menu and scroll through the pictorial list of parts for a "Spark Module". You can also try They also carry an inventory of parts for quite a few name brands. I hope this helps you. Please post back if you need further assistance.
Posted on Apr 08, 2008
Model E36GC65ESS
There is probably some dirt on the starter or the area near it where the spark should jump to. Locate the starters pin, where the spark would normally come from.
Use some WD40 to clean it and the area around it then dry it fully with a dry cloth.
Dec 16, 2013 | Electrolux 169036 LP 36-in Boiling Top...
I Have a C970-648229 and after self cleaning mode stove top stays locked out.
Have a similar problem. The range went on locked mode w/o it being used. Disconnected the cable & it unlocked but the touch panel would not work. The clock & the stove top continuos to work though. Appreciate any help. Thank you.
Sep 09, 2012 | Kenmore Kitchen Ranges
Kenmore gas 4burner cooktop model#229c44330p001-0 when its off the pilot keeps clicking(sparking) every 5-7secondstcarthen@
There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes. The next thing to check for are theignition switchesunder the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a badsparkmodule which should be replaced as sometimes cleaning can get moisture into the surface switches; try drying them with a hair dryer to see if this will help. Hope this helps...please post back for further assistance.
Jun 21, 2011 | Kenmore Kitchen Ranges
I hav a Viking professional. Only one burner ignites.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
Mar 18, 2010 | Viking 42 in. Professional Series...
Clicking on stove top will not stop
Unplug the stove top for a few days, and let the burner switches dry out. Sometimes this is caused by moisture getting into the switches from a boil over, or from someone cleaning the stove top. If your unit still sparks after a few days then you will have to replace the bad burner switch, or switches. I am assuming that you are talking about a cook top that is sparking all the time, and not about a cooktop that is sparking, even after the burner lights. If your burner is still sparking after it lights, you usually have a bad spark module. Good Luck, Appliance Specialists
Jan 17, 2010 | GE Kitchen Ranges
How do you clean the un-removable burner tops
I have a MGR4452BDW. The burners turn 1/4 turn, then pull out. Yours should too.
Feb 23, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
