Question about T-Mobile Dash Smartphone
I have a T-Mobile dash and cannot get it to charge.
I have a t-mobil dash and cannot get it to charge. It appears that I have a loose adapter plug (the part on the phone). When I plug in the charger, the cable is loose in the phone and the light will not come on showing the phone is charging (battery is dead, so cannot see screen. Have been told its not the battery.
Any suggestions?
WELL I TRY YOUR SULUTION BUT IT STILL NOT KEEPING THE CHARGE AFTER CHARGING THE BATTERY WITH IN 10 MINUTE THE BATTERY HAVE NO CHARGE AND IT IS A NEW BATTERY
Posted on Apr 14, 2008
  • 44 Answers
Do you have other phones or chargers? Most Motorola cell phone chargers will fit the dash as will some digital camera chargers.
Posted on Apr 07, 2008
How do I charge my Motomaster Mobile Power Pack Model 11-1540-2?
It should have a small 120V to DC wall adapter charger with a DC wire / connector jack that plugs into the back of the power pack. Plug the wall adapter into 120V outlet and plug the DC connector jack into the back of the Power Pack. Leave on charge until the unit indicates it is charged fully (several Hours if it was fully discharged).
Nov 20, 2016 | Electronics - Others
Need DC car adapter for Duracell powersource mobile 100
the positive pin is the one to the right when looking at the power connector with the mobile 100 standing up correctly, the negative is the one at the far left. I made mine start charging this way: Still don't know what the middle pin is for. Just make your own cable out of an old car plug and possiblly a pc power source connector. it's not that difficult.
Apr 20, 2013 | Xantrex Technology Duracell Powersource...
Samsung gt e3213k charging problem.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 07, 2012 | Samsung Cell Phones
Phone will not charge battery from any source, ac adapter or dc adapter.
First Option:
Aug 04, 2012 | HTC HD2 Smartphone
My mobile battery not charging
POWER SUPPLY & BATTERY PROBLEM
If thecell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.ORThe charge adapter is faulty. Test the voltage on the adapter plug with a multi-meter, the voltage should be slightly higher than the voltage on the label on the charge adapter.
Apr 27, 2012 | Samsung SGH-e317
T-Mobile Dash screen won't light
Consult_roxa
You can open it up and see if the lcd cable has come loose.
The following link provides directions on how to replace you screen. You only need to go to step 7.
After resetting the cable, and it doesn't work, then you probably need a new screen. I provided a link below where you can get those.
Reseat LCD Cable on T-mobile Dash
Replacement LCD Screens for T-mobile Dash
Hope that helps you out.
Nov 12, 2008 | T-Mobile Dash Smartphone
Won't stay on/ blank screen
2 things-
If the screen is blank white then the cable is probably loose: Follow this guide but just reseat the lcd cable
How to Fix T-mobile Dash LCD Screen
For the software issue:
The Windows Mobile installation may be corrupted.
The only way to fix that problem is by re-installing the windows software on the phone.
You can get the software for the T-mobile dash at the following link: http://www.t-mobile.com/wmupgrade/
Dash phone battery won't charge using 3 different chargers
T-Mobile Dash charger input not recognizing it is plugged into charger. Tried 3 chargers...
Nov 01, 2008 | T-Mobile Dash Smartphone
Battery?
if you have your wi-fi running all the time and if its constantly searching for wifi service it wil eat up your battery in like 5-6 hours, and make sure you use ONLY t-mobile dash charger, it does make differance,
Sep 02, 2008 | T-Mobile Dash Smartphone
Palm LifeDrive not charging
I had the exact same annoying problem. Easy fix though. Get the palm universal cradle. The power connector is either worn or loose and making partial contact. So when you use the normal adapter there might be a position that works but generally it won't. When you use the cradle the weight of the LD presses the contacts more and it will behave.
I went through a couple of chargers before getting the cradle and fixing it once and for all.
Apr 16, 2008 | Palm LifeDrive Mobile Manager Handheld
T-Mobile Dash Smartphone Logo
83 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
