Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Anonymous Posted on May 24, 2010
There is a flashing red light on the bottom of the tv, and it only turns on for a second then turns itself back off...help
  • Steve Allison
    Steve Allison May 24, 2010
    Does the set ever come to any video or audio? Knowing this would help.
  • Anonymous May 24, 2010
    no, it just turns itself off after 2 or 3 seconds...
Christopher Stearns
Level 2:
  • Expert 101 Answers
  • Posted on May 30, 2010
Christopher Stearns
Expert
Level 2:
Answers
101
Questions
0
Helped
41323
Points
217
Ay mine same thing read at this page do the reset how it says then turn it off and it should be reset worked 4 me ...........
here is the link
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1287
Points
I have the same problem witha wega tube CTV can hear sound then turns itself off no picture ?
Steve Allison
Level 3:
  • Sony Master 5,569 Answers
  • Posted on May 25, 2010
Steve Allison
Sony Master
Level 3:
Answers
5569
Questions
Helped
2001377
Points
16452
Then the problem is in the main power supply section and will need to be analysed by a technician; if you can find one for conventional TVs in your area. We are becoming rare.
If the set had been otherwise OK before this failure, I would recommend having it repaired since it will probably outlast any new flat panel set you might buy, they are not very reliable and service for them is expensive.
You can check for yourself by doing a search here at Fixya on 'LCD TV' and you will see a variety of makes and models with problems, many of them only a year or two old.
  • Steve Allison
    Steve Allison May 29, 2010
    Andalex: Your problem is not likely caused by the same failed components as the original poster.
    If the audio section is still able to produce sound, even if only briefly, the area in which the problem is likely to be is the high voltage/horizontal sweep section that is responsible for producing the ~25KV needed by the CRT and th signal that moves the trace back and forth across the screen.
    Certain types of components in this same area can cause the set to shut download because of excessive current being drawn and that this is delayed somewhat, the audio circuit can operate briefly.
    My advice about having the set repaired applies here too. . .
2 Related Answers
Anonymous
  • 12 Answers
  • Posted on Sep 23, 2007
SOURCE: Sony KV-32HX15U Flashing standby light
did you ry to unplug from the wall for at least 3 min then plug back in if that does not work try pushing the tv button and reset at the same time on the remote for 1 min if this does not work please take it to a repair center
Anonymous
  • 525 Answers
  • Posted on Sep 11, 2009
SOURCE: My Sony Trinatron KV32F16 tv was working great.
This is a hardware problem which can't be done by the owner of this tv. Try to find a technician who will help you.
2answers
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
1helpful
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
4helpful
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
2answers
Tv will not turn on--- flashing red led
I'm sorry, I don't have a solution, but I seem to be having a similar problem. When I turn my TV on, the green light comes on like it's powered up, but then the TV turns itself back off and the red LED light flashes. I can't do anything to turn it on or anything.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
