Question about Weber Genesis Silver C Grill
I move mobile homes for a living. I have a weber omni hitch on my toter truck. I have replaced the switches, plugs, and wiring on the controller. The hitch goes in and out, up and down, and left and right. I have had an intermitent problem with the hitch mostly not wanting to go right. Now it is no longer intermitent and won't go right at all. The spool valves are not stuck. The pump is operating at 2600 psi. It is supposed to operate at 2500 psi. Have had the reservoir off and it is clean inside and the filter is clean also. There is a light on the magnet spool valve assembly idicating that there is power reaching each assembly of which there are three. One controls in/out, up/down, and the third left/right. The ownner of the company said we still might have a bad wire between th light and the magnet so we replaced the middle spool valve assembly which controls the right/left directions. We replaced it on the weekend so I couldn't get them on the phone for more troubleshooting ideas. There are no leaks any where so I susspect that there is a check valve that is stuck or some other problem with the cylinder that pushes it to the right. How do I check the left and right cylinders to see if there is a problem? what would I be looking for? And what needs to be done to fix any possible problems with the cylinders?
burzerko
  • 254 Answers
SOURCE: Gas grill not lighting
Sounds like you have a faulty regulator. If you replace this make sure that you get a replacement of the same size.
Posted on Jul 22, 2008
  • 3 Answers
SOURCE: Weber Silver B - 3 burner BBQ
Check your instruction manual, you have probably set off the safety valve in your propane tank. It is set to trigger if there is an open connection, such as turning on the jets when the tank is turned off. You may have to re-connect the tank...careful of course, make sure it's valve is off.
Posted on Aug 24, 2008
  • 3 Answers
THIS IS YOUR ANSWER RE: LOW HEATING:
http://www.weber.com/support/faq/faq.aspx?id=1
Posted on Aug 25, 2008
  • 5 Answers
SOURCE: Weber Genesis Gas Valve will not turn
If the valve is stuck and wont budge, the only real solution is to have is replaced. Unfortunitly, Weber does not sell the valves separately and you would have to replace the entire manifold. Before going out to buy the parts, call Weber to see if your still under any warranty, even if your not they still sometimes send parts at no charge.
Posted on Mar 07, 2009
  • 512 Answers
SOURCE: Weber Silver Genesis C regulator purging gas after reset process
This could be caused by a couple of problems. First the regulator could be bad, or the tank is getting to hot. Which causes the relief valve to open and release pressure. This will happen when weather outside is hot.
Posted on Jun 17, 2009
Turn signal flashes fast but bulbs good
First place to check is for a bad wire connection in the hitch plug as it may be shorting out on another wire.
Mar 18, 2014 | Dodge Caravan Cars & Trucks
Need wiring diagram for a 1974 Fleetwood Glenbrock mobile home
FIXYA DOESN'T HAVE ANY WIRING DIAGRAMS, SORRY.
Jul 09, 2012 | Cars & Trucks
Just bought summit s 670 natural gas 89208 grill. Bought a display model because it was the last one they had. It was already assembled, so I took it home as is. Everything works great - except....the...
To determine if it is the switch, remove the wires from the back of the switch and touch them together, if the lights come on, it is the switch. You will have to contact Weber for a new switch.
Jul 17, 2011 | Weber Summit S-670 Gas Grill
Weber Genesis Silver C Grill Logo
99 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
