Tube guitar amp only has a hum. No other sound.Its not the tubes,not the 1/4" jacks,and not the speaker.For the hell of it I checked continuity on speaker wires,unplugged from speaker.There is continuity there with amp unplugged from the wall,is this normal?A 15k cement resistor also has continuity but still measures 15ohms.Is this normal? Talking about a 1988 fender champ 12,with pc board.Any input on what and how to troubleshoot would be very helpful.Thanks,Jim.
  • perkinsj Apr 07, 2008
    hi, I thought it was the caps,but I didnt want to just start replacing parts without being sure.What about the 15ohm resistor?It has continuity when none of the others do.Thanks
    Genius:
  • 3,422 Answers
you should only have one earth connected on your equipment to avoid a earth loop situation preferably the amp lift any other earths/ effects ect. to remove the hum loop if it is on its own and out of guarantee or a reasonable period say two years from the purchase date get a engineer to change the smoothing capacitors on the power supply look like to medium sized batteries on the power supply module as they are very prone to failure on trace elliot gear this should cure.
For more usefull info. please click HERE
Goodluck,
Please don't forget to rate the solution as fixya.
Posted on Apr 07, 2008
  • Priya darshan Apr 07, 2008
    Was that comment for me?
    President:
  • 2,267 Answers
I would suggest to check the power supply section for defective capacitors.
  • Jaime Hernandez Apr 07, 2008
    Here is the schematic diagram.
    If the value is 15 ohms, it will measure as continuity on the ohmmeter when using the continuity feature.
    Try to set the ohmmeter to ohms to measure the resistors.
I have a Blues Deluxe it has started making a in and out sound similar to higher pitch hum but in and out at a constant pace
check out your tubes....it sounds like one is working its way out of its socket or you have a microphonic tube...may be time to replace them and have the amp serviced while you are at it. ...Does one tube have a whitish look? inspect them/.....are there any cracks? while it is on...tap them with a lead pencil...something NOT metal...does it make a loud noise? These are all indicators there is something going on with your tubes..Good luck
Feb 26, 2015 | Fender 2232200000 Blues Deluxe Reissue...
Fender Hot Rod Deville 212 sounds ok then LOUD HUM
On mine, the guitar input jacks get tarnished and causes all kind of interference and noise. Take a Q-Tip soaked with WD-40, run in down into the jack and brush up and down. Don't overlook the filter caps as they are a common cause of noise. You need a capacitor checker (the older tube type) to thourghly check those out.
Sep 05, 2014 | Fender Musical Instruments Corporation...
Guitar amp continuous humming from speaker
Firstly, do not disconnect the speakers from the amp when it is on. Damage is possible.
You have a bad ground somewhere in the hookup. The first suspect would be your guitar-to-amp cord shielding connections at each plug, then, the wiring in your guitar. Try changing each of these to another as a trial, one at a time.
Here is Marshall's spiel on hum
http://www.marshallamps.com/support/faq/hums-hisses/
Mar 11, 2014 | Audio Players & Recorders
Bought amp 1 year ago, three months ago, no sound, Guitar Center said call an authorized repair shop. I did'n't open it up to check fuse because i didn't want to void the warranty. The shop replaced the...
Possible that the output tubes that were replaced are drawing too much current, hence the popping sound (may be "motorboating", one common word to describe a similar sound)
This means the tubes need to be biased properly. You need to get it to someone who knows what they are doing, ie a good amp tech, not GC. The voltages here are dangerous.
Feb 25, 2011 | Marshall JVM410C 100 Watts Valve Guitar...
Twin tube amp. power comes on, no sound. replaced tubes, still no sound
Do you have the speakers connected properly?? If so, maybe speaker wiring needs checked.
Feb 19, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
My deville has just stopped producing any sound what soever. All the tubes glow and the red power light is on but no sound. I have tapped the sides of all the tubes and they all register a sound except the...
The first thing i would do is not leave it on in this way for too long. You could blow out a very expensive Transformer if its a faulty speaker. The worst thing you could do to a TUBE amp is run it without a speaker . I would test the speaker first. Just remove the wires going to it. And connect the speaker to either a car stereo or house system at low volume very low. And see what you get. if it works ? Good! Now check your guitar chord/wire. Try different ones try different guitars. If that doesn't work . Look into the input jack on the instrument input hack on the amp.. They do come loose off the board.Either get a new input jack or resolder the old one. if you only have one guitar look at the guitar output jack. Loose wiring on the guitar could cause this also. Dirty In and out put jacks could cause this. A pencil with Very fine sand paper wrapped around it will clean a dirty input/output jack. Try these things. Just remember poking around your amp is Dangerous. The electrical components hold a charge even unplugged that can kill you. No joke..
Dec 26, 2010 | Fender Hot Rod Deluxe Guitar Combo...
My Garnet Pro 200 tube guitar amp has low volume
You must first isolate the stage that is causing your problem. Start at the master volume control by injecting a signal using a screwdriver. If you get a good level of hum from the speaker then output and phase splitter stages are ok. Work your way back to the front end by touching the screwdriver to inject hum into the input grid of each valve in turn to isolate weak stage. Check anode and cathode voltages on valve of suspect stage. Check cathode bypass capacitor and anode/grid coupling capacitor for open circuit. If fault in output stage check screen grid resistors for open circuit. WARNING high voltages exist in valve amps, keep one hand in your pocket and do not hold on to the chassis while testing.
Feb 21, 2010 | Audio Players & Recorders
Marshall VS65R is powered up it hums
Blown speaker NO (would not get sound at all)
Bad Reverb UNLIKELY (controls would deselect reverb and it would be out of circuit)
Bad preamp tube NO (controls have no effect)
Bad rectifier and/or filter caps LIKELY
Bad power amp POSSIBLE
Nov 29, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Hi, Peavey Classic Guitar amp , Has NO SOUND
Hi Mike,
If you switch on the amplifier, do you hear nothing at all?
Or do you hear low level noise or hum out of the speaker?
Don't know if you're technician.
If the tubes are glowing, you can measure the high voltage.
Check also fuse 3 and 4, thats the neg. voltage -27V and -14V.
regards,
Gerard
Jul 06, 2009 | Peavey Audio Players & Recorders
I was playing guitar through my fender 85 amp and the volume suddenly cut out to almost nothing and I couldn't make it loud again?
The speaker could be blown. Try touching a 9volt battery to the terminals on the speaker. If the speaker makes a popping sound its not blown. The other culprit could be the input jack of the amp. If its soldered directly to the board. The retaining nut may have come loose and the jack wiggle around with the cord tension. resulting in a solder connection breaking at the board. But that usualy will give a ground hum or no sound at all. So im leaning towards a blown speaker. (providing its a solid state amp) If it's a tube amp. it could be that one or more of the power tubes are bad or have a vacuum leak and may need to be replaced. ( you have to replace all the power tubes at the same time and have the amp biased.
Aug 19, 2008 | Audio Players & Recorders
56 people viewed this question
 Grubhead
Grubhead
