Question about Refrigerators
REAR BEARINGS I just bought a new kit to fix the rear bearings on my dryer but it didn't come with instructions. I did find a diagram on line but I can't find instruction. Only thing I am not sure about is where the one little bearing goes and what is the tube of liquid for. By looking at the picture I am sure I can do this. I did figure out how to take everything apart :)matter of fact I am working on another dryer also.I am replacing the blower fan. My husband won't get off the sofa so I really don't want to buy a new dry when I have two that can be fixed. So I am going to do this and show him .
  • Anonymous Apr 08, 2008
    Dryer is up and running :) Did most of the job myself,but did have my nephew help. Two pairs of hand are etter then one!! Thanks again.....Sonia
Thanks this sounds great!!! I know I can do it now...might have to get one of my boys to help hold things in place. Will up date later when I get home from work today! This was a big help!!
Posted on Apr 07, 2008
    President:
  • Refrigerators Master
  • 2,651 Answers
YOU GO!!!! thetube of grease(lube) is going to be used after your done installing the plastic cup that holds the rear bearing, your gonna fill that plastic "cup" with the lube fill it to the top you wont need it for anmything else so use as much as youd like. and for the little ball bearing in the kit, that actually goes behind the "cup" ( youll see a little impression om the back of the cup to allow it to sit. adn is held in by the pressure of the rear mounted clip..I use a little dab of the lube on the ball bearning to hold it in place while securing it
hopefully this if a free standing dryer adn not part of alaundry unit. getting acess to thje rear of the unit will greatly ease the changing of the kit.youll see that as you remove the 2 5/16 screws hoolding hte old mounting braket in place , you nee to sorta staddle the mahine in order to hold the cup and reach the rear screrws at the same time., the only other tricky part is trying to screw th e3 screws holding the bearing post to the rear of drum, i have found that it is much easier to thread the screws into the plate, before trying to install for the first time, and oh yea if at all possible irs actually not a phillips #2 screw, that will work but might strip out a little, the correct size is a roberts bit #2(square bit)
SOURCE:
Siemens WTXD8500UC/01 dryer makes scraping/grinding noise
Your bearing(s) on the drum need replaced. Do a search for appliance part, enter your make and model number and find the diagrams that will show the bearings. There are front and rear bearings. Note: they will not look like a traditional bearing so just find the diagram and search for bearings
May 01, 2017 | Siemens Dryers
Maytage Neptune very loud in spin cycle what is wrong
The rear bearing is going out. The motor will overheat from the increased load and the motor control board will soon fail unless this is fixed. To replace the Maytag Neptune rear shell bearings first order the seal and bearings. Here is the kit.
Oct 14, 2012 | Washing Machines
1994 Kawasaki ZX-9R Ninja replace the rear wheel bearings
Hi, Jacob_mccoll for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How To Change Wheel Bearings On Motorcycle All Balls Wheel Bearing Kit
1986 Ninja 600 Wheel Bearing change
KAWASAKI ZX900 C1 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 04, 2010 | 1994 kawasaki ZX-9R Ninja
Help! My indesit IS60V tumble dryer is banging and dancing
Have the rear bearing and shaft checked. Had same problem briefly until it stopped all together. When I looked at it, I found that the drum rear shaft had worn through the bearing and had been riding on the rear panel. This caused the rear panel, being thin to wear through the shaft until it sheared. This could be repaired by replacing the bearing and rear shaft for around £30 but in my case I'll need to the check the motor isn't burnt out too.
Apr 12, 2010 | Dryers
I have got a Hotpoint Aquarius tumble dryer. I have just put a new belt on it and a new rear drum axle with new bearings and front bearing pads.I have made sure that the front of the drum is sitting...
Make sure that you have fitted the spacing washer provided with the bearing kit on the drum shaft, and that it is sitting between the rear of the drum and the rear bearing, double check that you have got the front of the drum sitting on all the plastic bearings at the front.
If it still catches, then fit another washer on the drum shaft to space it off from the rear of the cabinet.
Mar 25, 2010 | Hotpoint Dryers
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
Where might I be able to find the rear drum bearings?
first off, what model dryer do you have? More than likely your rear drum bearings are towards the back of your dryer, but they may also be drum rollers. you need to access you dryer from the front on most models.
Jan 14, 2010 | LG WM-1485FHD Front Load Washer
Need to find specs on replacing rear spider gears on my 2000 e250, a friendly mechanic took a ride with me and said i need new ones...how difficult to replace, and where do i find instructions, thanks
first you have to find out what you need, could be bearings, worn gears or spicer assemble, all kits come with assembly instructions, some even require special tools to line up the pinion to crown, if there is any worn particles the real axle bearings should be replaced as well, its best to pressure clean the axle assembly thoroughly, and prelube all bearings
Nov 27, 2009 | 1999 Ford Econoline
Hotpoint tumble dryer making a banging noise, is
This could be a simple fix or more of a major task, so if you think you can have a go then great, first find tools and torch, empty any clothes, unplug from the power supply,disconnect vent if any, place unit on a table or bench then remove the back check for large quantities of fluff and dust, clean as much as possible, see if drive belt is secure and not damaged if this is not the case then the drum bearings may be worn, try to move the drum up and down, try the same thing from inside the door, as these dryers tend to wear front bearings quicker than rear ones, if excessive wear and you are confident, remove the drive belt and tensioner take note of the layout, remove supporting bracket at rear of drum taking careful note of where any nuts bolts are from, withdraw the drum you should now have access to all the bearings which are usually like a special plastic runners or ring, contact local supplier stating make and model number ask for a bearing kit, replace bearings and rebuild machine, all this could take up a few hours to a few days so ensure you can manage without a working dryer.............good luck
Nov 19, 2009 | Hotpoint Dryers
Hotpoint tumble dryer is making loud scraping noise like the drum is catching against one the panels
This sound is caused by the drum tilting towards the rear panel just above the heating element housing and is due to the drum spindle wearing through the bearing. (Which can lead to it shearing off) after it`s cut it `s way into the bearing support bracket. A new rear bearing kit is needed. it will come with a foam support which is stuck on to the inside of the back panel as the drum rests against this when turning. the foam support on your dryer may have perished or gone flat due to the heat from the element and that is why your hearing the scaping sound. new foam ring from the bearng kit will cure the scraping.
Sep 10, 2008 | Dryers
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
