Hello there:
In order to get to the fuse you will first need to remove the outer cover this is done by removing the 6 or 8 screws that are on the back panel the screws that are along the edge .
Next remove the screws that are on the sides there should be 2 or 3 per side.
Next the cover should slide to the rear about 1 inch then it should lift off from the rear and up once the cover is off look on the side and you will see a circuit board that has the fuse on it now simply remove the fuse and replace it with a new one
NOTE### MAKE SURE THAT THE FUSE IS THE SAME MEANING WATAGE ECT OK
once the fuse has been replaced plug in the microwae and see if it now works and if so great just put the cover back on and you are in buisness again but if it still doesent work you may have a inverter problem this is the part that gives the microwave its power ok
Hope this has been very helpful for you
Best regards mike
