Question about E-Machines T3265 PC Desktop
Wont boot My pc was booting up sometimes and sometimes it wouldnt. Now when I try to boot it up it says Check pc and signal cable. Someone had told me to replace the power source so I did but that didnt hepl either.
  • martylips Nov 30, 2008
    e-machine T2862 won't start cpu-----but monitor does start
    Scholar:
  • 82 Answers
I think the problem is with DRAM(memory) it is either not properly mounted or it is not working already. If it is not working already the best that you can do is replace it with new one. If you do have more than one DRAM you should check which one need replacement, you can do that by plugging the new one together with the existing one. You can identify which one isn't working anymore because the older that is combined with the new one will not boot the PC and the good older one when combined with the new one will boot up the PC.
Posted on Oct 16, 2012
  • Jimix Eouex
    Jimix Eouex Oct 16, 2012
    P.S. when replacing consider if it is DDR, DDR2 or DDR3....DDR3 is the latest and also speed of the DRAM should be the same as required by the motherboard..
    Novelist:
    Champion:
  • 236 Answers
If you know how to dis-assemble the parts of your PC, then try to clean connectors, display card, memory. The CPU mounting... be careful to remove the cooling fan then move the cpu retainer arm back and forth that is to regain better contacts of cpu leads. if you have an spare keyboqrd, try replacing it, if you have sa defective keyboard controller then you will have failure to boot sometimes. after cleaning the PC pheriperals, put it back and reset your BIOS/Cmos and configure as you neede, basic fail safe setup.
Posted on Apr 07, 2008
I have a dell precision m70. It fails to boot. The
How many times! Check the file system in the hdd.
Oct 21, 2014 | Computers & Internet
Well my cpu wont boot up it gets the the compaq screen but after that nothing i tried to boot it in safe mode recovery and normal boot but nothing happens its not the monitor and i dont think its the vga...
its not the problem of the vga signal.... try any of the following
1. take out the RAM and clean and reinsert it firmly. 2. enter the bios, check whether the booting device is appearing...it might be ur hard drive..if there is not boot device detected, try changing th e booting priorities.. and reboot 3. if your booting device is hard disc, try with the new hard disc after confirming the old is not detected in the BIOS..
and above all make sure all the connections were good
AND PLZ RATE this
Jun 23, 2010 | Computers & Internet
Moved computer to new location now I cant get it to boot, it shows poer but wont boot
there is some issue with connectivity or ram may be disturbed. For that remove the ram from motherboard and clean and reinsert the ram. Before that you check cables because you are saying someone removed cables on motherboard. plug all cables and try this
Jun 19, 2010 | MSI 865PE Neo2-V Motherboard
EMachines T3656 Desktop wont boot and no signal to monitor
Try to check the monitor cable if it is properly connected to your motherboard. If you will have a video card you need to attach your monitor cable to the video card.
Jan 28, 2010 | Computers & Internet
P4M800 Wont boot
Hello there:
please try this first unplug the power to the computer
next open the case and unplug all of the cables and cords that connect to the harddrive cd rom ect ect
now locate the power supply cord that goes to the motherboard and disconnect
press the power button on the computer for 20 seconds and also if you have a reset button press it . what this hoes is releases any stored esd that is in the computer ..
now plug in the power supply back into the board and plug in the power cord and try to boot the computer and see if it comes on if so great just plug in the cords to the cd rom harddrive ect ect and than reboot and you should be ok
Sep 23, 2009 | Biostar P4M800-M7A Motherboard
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
Wont read HD
It could be that the the HDD controller on the motherboard is gone, that's why it does it with several HDD. By the way go under the BIOS and check the Boot sequence, make sure that HDD is first, because pxe error occurs when you select to boot the computer through a network device. If it doesn't find it, that's what it shows on the screen, it can find the MBR.
Apr 02, 2009 | Computers & Internet
Wont boot even with factory cd
When you swich on the laptop push f10 to get in to bios, there is a feature to test the HDD(there was on a hp laptop few days ago), see if that says anything useful (that should take a while), and try to change the boot sequence at boot options, first should be the cd/dvd rom than the hdd. This way your pc will try to boot from cd first, if nothing than Hdd is next.
Than you should be able to boot from your CD, if not than open up your PC case and chack the cables, take off the power and data cables and reattach them, sometimes it does the trick.
Worst case scenario is that your HDD is dead, if you got warrenty left than use it, if not than buy a new one from the local store or order one from ebay or zipzoomfly, just check what type do you need, the size is up to you, even 500GB drives are quite cheap nowdays. You need to open up your pc and check what type of cable is going to the HDD it can be IDE or SATA to know for sure what type of HDD you need.
Nov 23, 2008 | HP Computers & Internet
Computer wont completely boot
Nope a bad battery will not keep a machine from booting..
Does it shut off or do you get an error or does nothing come up when you turn it on???
Dec 18, 2007 | Computers & Internet
E-Machines T3265 PC Desktop Logo
64 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
