Question about Husqvarna Designer I
I accidentally started sewing with wrong foot and needle hit the plate and broke. Machine won't sew
Once I turn the machine on, nothing works. You hear a winding sound like the motor is running but it won't sew. i tried turning it on and off. Any suggestions? I also cleaned it around the bobbin case, took that apart. I was able to recover the entire needle so something isn't right with the machine. Obviously. HELP!! It is practically new.
  • suzque734 Jan 10, 2009
    i have this problem how do you see the drive belt. can i fix it?
  • 3 Answers
My Designer 1 has been converted to a USB drive and after using it very frequently for nearly 12 months it suddenly started behaving erraticly, the screen falshing on and off, onlt part of the screen being visible, starting to sew on its own. The only solution was to return it to the dealer (at first it wouldn't misbehave for him!!) and eventually, after he contacted head-office , he discovered that there there had been similar problem wth other units and he replaced the USB drive. Fingers crossed - it is now working well. Good luck
Posted on Jan 20, 2009
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
This is just a guess since I haven't seen exactly what's happening, but my guess is that the drive belt has come off. You can hear the motor running because the machine is attempting to bring the needle to it's fully up position. Since the machine isn't turning, the motor will run faster and faster until it hits full speed.
Posted on Apr 08, 2008
The needle is hitting the needle plate (and breaking, of course) instead of going through the hole to the bobbin
I am wondering if it could be an issue with the type of needle you put in there. I am having trouble with a sewing machine tension and the store people told me that you have to use the manufacturer/ original style bobbin (it's engineered to fit the gadget 'Just so').
I know on my non-computerized Brother sewing machine, that I can change the needle position to L/M/R and I see it move when I move it left and right.
I guess you've probably checked all of the other settings on your machine?
Is the presser foot coming unscrewed?
Mar 03, 2014 | Brother PE770 Computerized Sewing Machine
The needle somehow no longer lines up properly... there is nothing wrong with it or the foot area that I can see, it just hits the metal plate when I turn the hand wheel.
it sounds like the sewing machine needs to be checked at a sewing machine shop to see if it needs to a adjustment.
Aug 14, 2013 | Singer 4830
My machine won't sew since I replaced the broken needle
when the needle broke it's very possible that it knocked the needle bar out of time, & needs to be taken to a sewing machine shop to be retimed
Apr 07, 2012 | Sewing Machines
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Sewing machine timing problem
Singer sewing machine needle does not go directly down into opening of foot, it hits the back plate of foot. how can i align it.
Apr 23, 2009 | Singer 14SH654
Breaking needle
Sounds like the timing is off, have to take foot off, take plate off, put it in the zz position and using the hand wheel turn(with new needle in) and see where it is hitting feed dog, loosening the screws to the feed dog and moving it in the opposite direction out of the way so as not to hit. let me know how that works
Aug 08, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing with walking foot
Take the needle out and run the machine for a while with the walking foot fitted. Refit the needle and try again but only turn the machine over by hand to see if the problem has cleared. If no luck it sounds like the walking foot timing needs adjusting.
Apr 05, 2008 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
104 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
