Question about HP Office Equipment & Supplies
Ink system failure Oxc18a0105. I have tried the online downloads without success.
cschichtl
  • 43 Answers
SOURCE: ink system failure
it could be a viros or a printer jam
Posted on Sep 13, 2008
SOURCE: HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Posted on Nov 21, 2008
SOURCE: HP Photosmart 8250 Ink System
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Posted on Jan 02, 2009
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
bschilz
  • 2049 Answers
SOURCE: I have an ink system failure Oxc19a0036 on my
Follow this link to see the story of how one user fixed this problem...
http://www.fixyourownprinter.com/forums/printer/50063
Posted on Nov 27, 2009
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
I has an issue with my Photosmart C8180, it shows Ink System Failure-- I tried it online but did not find it, Is there no Resolution available for it, Please help me with it,
HERE IS WHAT YOU SEEK
Issue: An Ink system failure message and error code appears on the printer display.
Solution:
Step one: Reset the printer
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
Press the On button to turn the printer on.
If Ink system failure does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, continue to the next step.
Step two: Download and install firmware update
Go to the product support page to download the update.
http://h10025.www1.hp.com/ewfrf/wc/softw...
Click Software & driver downloads.
Click on the appropriate operating system link.
Click on the Recommended update to fix long power-on cycle and ink system failures link and follow the instructions to download the file.
After downloading is complete, disconnect all other USB devices from the PC. Make sure the product is powered ON and plugged into the USB port.
With the printer directly connected to the PC, click the downloaded file FirmwareEnable_Release.EXE.
Click Open/Run.
Click OK at the Update successful window. The error should have been cleared from the printer display.
If you get a message saying a device was not detected (see Figure 1), make sure the printer is powered ON and the USB cable is connected to both the printer and PC and try step five again. Source(s):
Nov 10, 2010 | Office Equipment & Supplies
Solution for Ink System Failure
try a simple power reset if that fails then it may be hardware issue it all depends on the error code of the ink system failure. depending the printer and the cartridges you may have to call hp to have a specific reset done on your printer and it is a one time only reset if it is successful
Apr 06, 2010 | HP Office Equipment & Supplies
Ink system failure
The error is caused by air in your ink feed tubes. We have a guide posted on our web site at: www.ccl-la.com that will show you how to do a purge of the air and get back going. Look on the printer repair page and the the HP link. This will have to be done with a new set of ink cartridges.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 28, 2009 | HP Photosmart C6280 Printer
HPC8180 Did not follow intitial instructions and now have ink system failure. Hp unable to help sent me brand new ink cartridges, I tried to reset with no success. Any help?
Follow the instructions on this web page http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/ to prime ink through the lines and hopefully clear the error. I don't know why HP sent you new ink cartridges when it should be obvious to them that the cartridges are not the problem.
Nov 25, 2009 | HP Photosmart C8180 InkJet Printer
Oxc19a0023 INK System failure
TRY THIS
Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say "Enter Special Key Combo"
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
Press and release the "OK" button.
Display should say "Support". Use the Right arrow Key to look for "Reset Menu".
Press the right arrow key to look for "Partial Reset", press 'OK'
The printer will go off and will power on by itself, else wait for 20 seconds and power on the printer to complete reset
reset process for c6380
Apr 09, 2009 | HP Photosmart C6380 All-In-One InkJet...
Ink System Failure on HP Photosmart c5180
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart 8250 Ink System Failure,error code Oxc18a0007. I've tried HP site for solutions with no success. Also tried re-installing software,replacing ink (all genuine HP) but no luck!
Jun 17, 2008 | HP - HP Photosmart 8250 printer
219 people viewed this question
Ben Johnson
