Question about Dryers
I need to replace start button on dryer, frigidare model FDC747RE. How do I remove the broken button?
  • ochoa0700 Apr 07, 2008
    can you be more specific?
    Is there a way to release the start button other than breaking it apart? If I break the button housing will I be able to replace it myself?
  • 3,037 Answers
Have you tried twisting the old one off with a pliers? If you are only removing the button and not the rod, it should either twist or pop off and don't worry about wrecking it, look at the new button that you bought and see how it would attach to the rod so you know how you should pull it off
Let me know if you need any other help and good luck to you
Posted on Apr 07, 2008
  • Benjamin Patri
    Benjamin Patri Apr 17, 2008
    were you able to fix this using the information I provided or do you need more help?
  • Benjamin Patri
    Please don't forget to rate this solution for me
    Sergeant:
    Champion:
  • 427 Answers
I wouldnt personally tamper with a product of thet expence, but if you have to, you have to take a few things into concideration.
1.The buttons are set up for that if you wanted to remove them, they would have to be broken.
2. Call a local repair office and see if they could do it in a non-destructive way.
SOURCE:
Making a squlling noise while drying
have you checked the belt drive? Belt may need adjusting or replacement.
Jul 27, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its then you press buttons and it beeps continuosly...
that's a lot of kids... according to the Frigidaire wiring diagram and codes list E68 means a key is stuck or bad board. You can enter function test mode and check which button is at fault. Hope this helps Tim
p.s. here is a thread:
http://forum.appliancepartspros.com/dryer-repair/143380-frigidare-affinity-dryer-e68-error-code.html
Apr 06, 2011 | Dryers
How to replace a fuse in frigidare model gleq2152ee0
you will need to remove the lid,the the control panel then the front panel needs be removed then the drum need to come out depending on what fuse you are replacing. to remove the belt take off the small access panel on the rear and take the belt off the pulley.
Feb 24, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I have an err68? How do I repair?
E68 One of the keys (buttons) is Enter function testmode and perform key stuck closed (active). (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists, replace electronic control.
Sep 21, 2009 | Dryers
My Frigidaire model GLEQ2152ES0 will run but the air does not get hot.
Need to order the resistant heater, use the mothel of the unit to make the orther
Aug 11, 2009 | Frigidaire Electric Dryer
Frigidare dryer belt replacment
if your dryer is the one as pictured it is quite a job! I dont feel like writing a bunch of steps that may not even be the right model. Is the pic correct? Ill try to help if it is.
Nov 27, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
