Question about Nintendo Wii Console
No sound on nintendo wii
Everything else on the wii works except the sound we ahve tried the wires elsewhere and also the wii on a different tv set but still no sound what can we do. No sound coming from the TV. Wires are fine and tried different inputs, still no sound. Also tried the mono stereo and surround settings. Still no sound. This is a brand new Wii.
  • 3,037 Answers
Since it is new, I would think it is defective, please return it and get a new one and if the new one has the same problem let me know but most likely a wire or a joint inside the wii is broken or disconnected. Since it is new and still under warranty, don't try to open, just return. Thank you and have a good day.
If you have further questions, please ask
Posted on Apr 07, 2008
  • 19,396 Answers
May be faulty contact the neares t service and get it replaced
When i turn my Wii on it does not show up on my screen all the time. Sometimes it does but not always. It usually shows up as a black screen. Everything else on the Wii works and I can eject disks and its...
try changing to a different input on the tv, or a different tv if you can(if you haven't tried that yet). if it stops then you know it's not the game but maybe the tv or the input. they do wear out from things connecting and disconnecting. you could also try a new cable from the wii to the tv. unplug the cables and check the length of the cable carefully to check for cuts or exposed wires (pets can chew them ect...). if you find anything odd, replace the cable right away. if you have ever had you wii modded in any way, that could also be the problem. even if it was a while ago.
hope this helps
Apr 17, 2011 | Nintendo Wii Console
I got a new nintendo wii today and everything works fine but the sound doesnt come on what should i do? i made sure everything was lined up right
The quickest thing you can try is to connect it to another TV and see if it works.
There are various methods for connecting the Wii to the TV. In the box you should have a component video lead with red, white & yellow connectors. These can be connected directly to the corresponding inputs on the TV or you can connect them to the SCART adaptor and then connect that to a SCART input on the TV. Try using the red, white & yellow leads directly if possible, just in case the scart converter is faulty. If you have more than one set of RWY connectors on your TV then make sure you are using the correct set (you might connect the yellow video to one set and accidentally connect the red & white audio to another set). If you are using the SCART input then try swapping to another input if possible.
Make sure the all the connections are fully pushed into the Wii and the TV.
Feb 16, 2011 | Nintendo Wii Console
I have just purchased a used Wii system and every thing works fine except that it is in black and white help.
Hi Anne,
It could be due to the wii's current video settings, the previous owner would have had a TV that ran on different viewing options. The black and white picture is caused by having the Wii settings output at PAL 60Hz and the TV input at PAL 50Hz or vice versa (or NTSC). Try going to the wii settings menu and try a couple of different video settings until the colour comes :). If this does not work can you please post what connection you are using for ex. AV or composite.
Regards,
Omeil
Jan 30, 2011 | Nintendo Wii Console
Hello, when I connect my Wii to a Samsung 3D plasma tv I get a black and white (non-crisp) picture but I do get sound. When I do the same set up on a tube tv everything works. I tried the set up on...
a 3D tv is another form of an HD TV, you need the Wii HD cable to play it right, and make sure you plug it into the HD ports on the TV to get the color and sound back.
Sep 12, 2010 | Nintendo Wii Console
My wii system lost its red color. when i play wii sports everything mostly everything is green. i tried fixing my tv settings but its not the tv. ive tried everything. does anyone have a different idea on...
I have the same problem with my Wii. It's on everything, games, etc. Did you ever access the internet through your Wii. I do and I wondered if a virus hit it.
Sep 10, 2010 | Nintendo Wii Console
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
Bought a Wii and using the standard cables it played great on a new 50' Panasonic Plasma as well as on our 2 year old 32' VIZIO LCD. Just upgraded to a 46' Sony LCD (W series) and the Wii looks terrible...
The Wii can display on a HDTV, but keep in mind the output is only 480p. It is not true high definition, and it will only display this using a component video cable. There shouldn't be a difference with LCD and plasma.
You will also need to go to the display settings to force the Wii to display in 480p.
Try a different input (safe to assume your Sony has multiple?) and see if it is that specific input. Also, try a different device like a DVD player or VCR and see if you get the same result.
Good luck.
Dec 07, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
576 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
