Question about Kitchen Ranges
We have Magic Gas Chef Furnace/AC Model 38HWC242-5A. Last week, we had no heat. The repairman came and said there was a problem with the ignition. He said that the igniter was producing a spark but it wasn't being transmitted properly to the electrode. So he ordered and repaced the electrode. But this did not fix the problem. He now thinks we need to replace the circuit board. Are we on the right track?
  • adonigerAndy Apr 07, 2008
    In sending this request for assistance, the website asked for a category of the product. No category for furnace was listed. I chose "stove" at it was the next closest choice.
    This furnace is installed in a development of townhouses in Virgina nearby to Washington, DC. The Unit is 13 years old.
    This is a Magic Pak not a Magic Chef (Originally Armstrong AC then purchased by Lennox)
    Genius:
  • 3,422 Answers
The advice given to you buy the repairman is right.I suggest you to go ahead with the repair.
Hope your problem gets solved soon..
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 07, 2008
  • Priya darshan Apr 07, 2008
    You can also check THIS and THIS forum out for some usefull info.
    Goodluck once again,
    And please don't forget to rate the solution.
  • 3,037 Answers
It sounds like he knows what he is talking about, I would've done the same thing if he were me. Good luck
If you have any further questions, please let me know
  • Benjamin Patri
    Benjamin Patri Apr 07, 2008
    I would not doubt after 13 years that the board may have gone bad
Magic Chef CGR3742 Hi, I't has been pre heating, but took a very long time. Now it sometimes will heat up a little, but will not hold that temp. for long. I removed the bottom pan to see the burner and...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Tip
Magic Chef Gas Ovens
If your Magic Chef gas oven doesn't light, most likely the oven igniter (rectangle style) is the problem. The igniter may glow and appear to be working, but doesn't get get hot enough to open the oven bake valve. I recommend replacing the igniter first.
on Mar 21, 2010 | Magic Chef 31000 Gas Kitchen Range
NO heat on bake setting. All other functions work. for the last 2 weeks the oven has taken longer to get to temp & now there is NO heat.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 23, 2010 | Magic Chef CGR3742 Gas Kitchen Range
I have a magic chef gas range and the oven does not heat up
Just because it glows that does not mean it is not bad...
heatman101
Sep 06, 2010 | Magic Chef Kitchen Ranges
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Magic Chef Range in camp trailer, pilot light in the oven works however, the burner will not light when turned on. No gas flows. Propane furnace works ok and the propane bottle is full. The surface burners...
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
or
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Jun 14, 2009 | Tappan MGF500PBW Gas Kitchen Range
Get too much of a gas smell when Magic Chef oven prheats up.
gas does NOT take that long to heat up!!
Shut that thing off before you kill your family !!!
Take it back or call someone to fix it !
This is a ticking bomb you have,...
If You smell gas then you should call the city or 911 .
Jan 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Leak Safety Valve Magic Chef Oven?
that could be rigth only if that ignitor is good,,,that ignitor has to glow bright orange,,if its weak,,which it sounds like to me,,the gas will take a long time to ignitor,,or dont ignite and you smell a wee bit of gas,,,onthejob
Jan 08, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
