HI,
Can you please give me the model no. and the make so that i can help you fix the problem.
Waiting for your reply.
You can check THIS LINK out to fix your problem
Re-position the Encoder Strip on your Printer
To re-position the encoder strip, perform the following steps:
1. Remove the power cord from the unit.
2. Lift the lid of the unit, just below the scanner portion of the
All-In-One, to expose the inside of the unit where the printer
cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip down and then back
up to get it back into the slot located on the back of the ink
cartridge carrier.
NOTE
NOTE: There is a small slot that the
encoder strip fits into, which is going to be located on the back of
the ink cartridge carrier.
6. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the lid to the unit.
9. Re-connect the power supply to the All-In-One.
10. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
See attached pictures, one for an out or place encoder strip, the other for a well placed strip.
Other
faults that can bring up this error is a carriage rail that needs
cleaning and oiling (so you might want to do that while your inside the
thing), and also obstructions to the paper ways. Try removing paper
jams, and put the printer upside down to shake loose anything that
might jam the mechanism.
This one is of an out of position strip
check that, botom picture is of an in position strip, top of an out of position strip
What is the make and model please of this printer, thank you
Please go to the website below to learn how to clean the printer to fix the problem, I am assuming that it is a lexmark, even if it isn't this would be good to try because printers are very similar still
http://blog.forret.com/2006/02/lexmark-p.../
If you have any further questions, please let me know, otherwise
Good luck
Hardware Error: 0502.
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
There is no need to go through any more steps
