Question about HP Pavilion dv4000 Notebook
When I touch my keyboard my computer freezes
Two days ago I started the laptop and when I attempted to enter a web address the computer froze. After many trials I came to find out that the mouse touch-pad and buttons would work without fault but any key on the key board had fatal consequences. I also realized that the computer continued to process programs even though the keyboard failed to respond to the second keystroke.
I've run the antivirus programs and attempted to restore the registry but nothing has worked. In fact when I attempted to restore to an earlier date the system informed me that it could not process the request. So I'm Stuck.
I even thought of trying to find the default registry of this laptop and installing, but I haven't been able to find a copy on line.
  • GGrimes Apr 08, 2008
    Thanks to the both of you. I took the machine to a LapTop Tech. I told him of the new keyboard solution and in fact that is what I have had to do with another unity but I didn't suggest the re-formating of the disk (I hadn't received that suggestion yet.)
    He who informed me that a circuit or some piece of hardware that is located directly beneath the CDROM/DVD player was burnt-out. . .due to being over heated.
    Does that sound right to you?
    G
  • 520 Answers
Reinstall windows..but before you install delete partition,create new partition then format.suggest full format not quick.
gets rid of all lingering bugs.
you could check conflicts/sharing programs in system information but I doubt youll find anything,sounds like software running in background which could be anything from sys 32(which u need) to spy/malware which u definatly dont need
Posted on Apr 07, 2008
  • tat4u
    tat4u Apr 08, 2008
    dismantled there is nothing above nor below cd/dvd.the unit slides into a casing where the connection is at the back of it connected to the motherboard.when constructed all that is above or below of it is what you see every day.your plastic casing.
    there are parts in the cd/dvd which get very hot but this would only effect the running of it and disks not read properly.
  • 77 Answers
Click the link below for your service manual.
http://www.cluefree.com/technical/laptop/hpdv4000/hpdv4000maintenanceguide2.pdf
  1. remove the keyboard
  2. use a USB external keyboard and see if your laptop normalizes and becomes stable
  3. if this solves your problem then try to purchase your keyboard off ebay and replace it.
hope i was able to help you
Mouse didn't detected
Touch pad usb or wireless mouse ?
Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs. Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time. Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard. Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse. This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function. Press and hold the "Fn" button together with the mouse icon button. Look for the disable/enable symbol that briefly displays on your screen. Slide your finger over the laptop's mouse and attempt to use it as normal. Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter." Press the left arrow key to navigate over to the "Device Settings" tab. Press the tab key to reach the "Enable" button in this section. Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box. Press the space bar to remove the check mark. Put your finger on the touchpad, and move the pointer down to the "Apply" button. Click "Apply" to save the settings. Close the mouse "Properties" box. Press the keyboard "Windows" logo key to open the "Start Menu." Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart." Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function. Open the "Control Panel." Go to the "Add and Remove" or "Uninstall" programs section. Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse. Select the "Uninstall" option to remove any software and settings associated with this secondary mouse. Restart your computer and attempt to use the built-in laptop mouse as normal. Check to see if the mouse is working properly. Press the keyboard's "Windows" button to open the "Start Menu." Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel." Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it. Find "Mice and other pointing devices from the list" and open its "Properties" dialog box. Select the "Driver" tab and choose "Update Driver." Allow Windows to search the Internet for drivers and to update them automatically. Restart your computer after the drivers are updated, and use your mouse as normal.
Beginners Guide to Using a Computer Mouse? Tips and Tricks
http://tips4pc.com/basics/beginners-guide-to-using-a-computer-mouse-tips-and-tricks.htm Laptop not working - touchpad unresponsive http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Apr 14, 2013 | Acer Computers & Internet
When i press one of the Fs the computer freezes and i cannot access the bios or do anything ( cannot boots from CD )
1st try boothing up with a usb keyboard if you have one available. It may be the keyboard.
Dec 27, 2012 | Computers & Internet
A couple of days ago, my laptop froze. I tried Ctrl+Alt+Del, but that didn't do anything. This never happened before. When I rebooted, the computer froze within a couple of minutes and this happens...
Hello there,
There several reasons of the freezing. It could be a virus infection on the computer or a System problem. Try to boot from Safe Mode or "Last known good configuration". Reboot and continuously press F5 or F8 until it will show you the selection. Highlight to select Safe Mode or "Last known good configuration"then press Enter. It should reboot.
Please let me know how this goes so that I could further assist you. Thank you for using FixYa.
Oct 05, 2010 | Toshiba Computers & Internet
Why does the cursor freeze on my brand new computer (out of the box for about 30 minutes)? Acer Aspire 5534 Tried to create backup disk & cursor froze, restarted my computer & cursor froze again....
Acer has a recovery icon in desktop no need to back up a new PC.....But i would advise u take it back...that freezing is an error in the OS system
Dec 08, 2009 | Acer Computers & Internet
Laptop freezing acer aspire 5520
If you are carrying it around, and you are getting black lines across the screen, you have a lot more than thermal pads to be concerned with. The connections inside are breaking down and arcing. (That's what the ssszzzzzzzZZZTTT noise is).. Unless you are good at repairing printed circuit boards, you should take it to a repair shop.
Sep 17, 2009 | CMB T43 750 Notebook
When i plug in device in to a usb port my computer freezes up
have you tried a different USB port because theres two types of usb port & one on the back has pin's inside it check that these arnt bent or touching you should use the side ports for your basic everyday external devices.
Aug 12, 2009 | Computers & Internet
Configure my keyboard internet button
Its not a HW ,.. its a SW issue ...
try this if u can and hopefully it works !!!
1. Click Start on the taskbar.
2. Choose Control Panel.
3. Click Printers and Other Hardware.
4. Double-click Keyboard.
5. In the Keyboard Properties window that appears, click the Buttons tab.
6. Double-click the button you want to change. The button configuration window opens.
7. Choose the button capability from the drop-down list. Enter the Display label and the Address information. (For a Web site, enter the complete Web site URL in the Address box.)
8. Click OK.
9. On the Buttons tab, click Apply.
10. Repeat steps 6 through 9 for each button you want to reconfigure.
11. Click OK when you are finished reconfiguring the keyboard.
May 09, 2009 | HP Pavilion dv6000z Notebook
Magellan RoadMate700
I think Magellan makes it so if you don't update your map every year it will freeze up. Mine does the same thing and they told me to buy an update for $99 last year so I did and it worked and then after it started telling me my map was over a year old this year it started freezing up again. I don't want to pay $99 every year to keep this thing working. I wonder if Garman or Tomtom does the same thing.
May 31, 2008 | Magellan RoadMate 700 GPS Receiver
Frozen keyboard acer 5100
for aspire 3050, try to remove the battery, battery can cause many strange thing.
if you still got problem after removing battery, it's look like motherboard need repair.
Mar 02, 2008 | Acer Aspire 3000 Notebook
HP Pavilion dv4000 Notebook Logo
590 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
