Question about Brother MFC 210C All-In-One InkJet Printer
Trying to leave Machine
When I turn my painter the scanner slowly goes across but doesnt stop when it gets to the end it contuines to click as if it is trying to get out. The fax light flashes on then all the lights flash on. it use to go fine please help me.
  • 832 Answers
Do you receive an error message? Should be AF.
Open the scanner as done when connecting the usb cable. There is an "Z" looking cover going from panel to the right rear side. Open cover and simply take the flatcable out and reconnectit again to printers main board.
Posted on Apr 07, 2008
Will not spin out water
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
Apr 25, 2012 | Kenmore Washing Machines
Apr 24, 2012 | Kenmore Washing Machines
Scanner grinds when powers on
Its not drivers issue, hard ware issue.. Scanner assm faulty,replace it..For tech guys:Open flat bed glass, remove scanner assm clean inside reflector glass with ear buds & adf glass especially at home position.. lubricate on rail refix it back.. check it..
Dec 22, 2011 | HP Photosmart C4580 All-in-One InkJet...
Sharp CopierAL1661CS scanner function seems jammed. makes clicking noise the grinds but no movement across platen
Under the top left side above the paper exit tray, there is a glass like lock that either unlocks the platen or locks it. If you accidentally touch it when collecting copied papers, you locks the scanner motor causing that clicking noise.
Remedy
  • Check that lock and rotate it the other direction slowly till it stops.
  • If it does not solve this, open the document glass and check the the rail that carries the scanner. Oil it to make it smooth and no problem should occur. Also check that the motor is securely locked in its position.
Best of luck.
Dec 08, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a 2006 Pride Maxima. Problem comes and goes.
Hi Alex. Does this problem happen when you first turn on the scooter, or does it happen while you are riding the scooter.
It might possibly be that the speed lever ( wig wag ), is not correctly adjusted, or is worn.
Test the lever is correctly adjusted by sitting on the machine with the key on. Slowly move the lever in the forward direction, until you hear the brake click. Take note of how far the lever moved. Now move the lever in the reverse direction until you hear the brake unit click. The distance the lever moved, should be the same in both cases.
Also while you are driving your machine try moving the ends of the lever slowly up and down. If this makes the machine change speed erratically, then you probably need a new throttle pot, or speed lever assembly.
Does your machine show any fault codes or flashing LED's.
Hope this helps. Neil.
Jul 09, 2010 | Pride Luxury Line Maxima Scooter - 4 Wheel...
Feed dogs won't stay down
Your machine needs to go in for service.
In the meantime, try this:
Set the stitch length to zero to slow down the motion of the feed dogs.
Securely tape an index card over the feed dogs with a hole punched in the center for the needle.
Painter's Blue Tape works well as it does not leave a residue.
Do a test sample to see if this will work for you until the machine can be repaired.
Mar 19, 2010 | Husqvarna Viking 1
My HP scanner in my all in one wont work
I called HP and they told me that the reset for this is unplugging the power cord from both ends and waiting for a count of 60. At first this worked but each time the power goes out in our home, the next time I turn it ion, it does this and tells me there is a scanner error after trying to initialize. Keeps running back and forth somewhere inside and not clicking in. Unplugging and counting no longer work. One day I fooled with it all day and it finally stopped. Now power went out again and it's happening all over again! Very frustrating. Can anyone help?
Oct 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Canon image class MF5750 printer/fax/scanner
If you're in the USA, go to this link. Enter your zip code or city / state and click the "Find Service Location" button.
May 22, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
BOSCH DISHWASHER SGS 6312GB/13 , FD 7810
You have a leak underneath and it is switching the anti flood switch on. Tip the dish washer back at a 45 deg angle, you will probably get water teak out the back, stand it back upright and try it. although it will probably work you will need to look underneath and find where the leak is coming from, my guess is its the wash pump and will cost around 100 pound for an engineer to repair.
Dec 02, 2007 | Dishwashers
Brother MFC 210C All-In-One InkJet Printer Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
