Question about JVC AV-56P575 56" Rear Projection HDTV-Ready Television
Red burn? Shuttle, Saw you answered another 56P575 question, so I figured I would ask. My 56P575 has a pretty bad red push problem (people are starting to look purple on the screen). I also noticed that the non 16:8 area of the screen is burned at the edges where the vertical bars would go for non-16:8 broadcasts. What do I need to do/replace to make the pictue come back?
    Genius:
  • 1,139 Answers
I would suggest you take a look at the guns (CRTs) of the TV and determine if they are good, you will need a CRT tester to do this. make sure the CRT is working properly and then adjust the colors as needed. TIf the problem still occurs or the CRTs cannot be rejuvenated, you will need to replace all three CRTs (They are actually a match set).
Posted on Apr 21, 2008
SOURCE:
DeWalt 744 table saw stopped. Power to saw is ok. Checked breaker and cord. Also pushed red reset button on saw switch. No change
In your service Manuel you'll find the location of the safety triggers. It's highly possible one of them has a bad connection. Very briefly and carefully jump each one till you see a change to eliminate them one by one.
Sep 20, 2017 | Dewalt Saws
IS IT NORMAL TO VIBRATE LOUDLY WHEN PUSHING RED BUTTON TO RELEASE WATER? I RENTED ONE TODAY. IT PRETTY MUCH IS QUIET TILL I PUSH THE RED BUTTON.
Red button activates the pump, brushes and suction is my guess and pumps can be noisy. You could phone the rental place and ask. As long as it cleans your carpets, all is good.
Feb 17, 2016 | Rug Doctor Wide Track Carpet Cleaning...
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Cooktop red light is staying on
The red light is on as a safety to let you know the surface is hot. When the light goes out the surface will be safe to touch with out getting a bad burn.
Please rate 4 thumbs for the free answer.
Mar 16, 2010 | Whirlpool Cooktops
I recieved a 10 inch 3hp contractor table saw from a friend,for some reason im a bit slow in figuring out how to hook up the power supply plug to the motor. The power cord has two clips that push on to the...
if its 220 use red if not use the other two on the clips are they connected to each other in some way in group of 2 if it is just slip one on each group
Sep 10, 2009 | Saws
Color fine with rca jacks but when using hdmi/component its not
There may be a number of problems that are causing your HD issues. They may exist in your TV, or in the box you use to tune your channels. Contact your cable or satellite provider and ask them to change out your box. If the condition still surfaces, then you need to have your TV checked. The component and HDMI jacks are both connected to the same electronics. This is why they are exhibiting the same problem.
Jul 15, 2009 | JVC AV-56P575 56" Rear Projection...
How to re-insert bobbin shuttle
maybe one of the parts diagrams at the Singer site would help? or us the contact there?
Oct 29, 2008 | Singer 3116 Simple
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
