Question about Remington ES-1000 Electric Shaver
Hi just bought a new toaster today but stupidly chucked the reciept and manual away due to house clearing. PLugged it in but cannot work so am not sure if its faulty or just me not being able to figure out how to use it (which is unlikely as its just a toaster).
I have the same razor. If it has been sitting too long the internal nicad batteries may not accept a charge and this razor does require the internal battery to not be totaly dead even using with the power cord. Try leaving the unit plugged in for a week or so and see if it "wakes" up. It it is supposed to automatically charge when plugged in (leave the switch in the "off" position). Mine did eventually wake up and I got another few months useage out of it. The internal two cell nicad batteries are soldered to the circuit board inside and are NOT easy to replace. I happen to like the design of this razor to prevent ingrown hairs and Remington does not seem to have anything like it for sale anymore. This model has been discontinued as well as replacement blades.
Posted on Feb 05, 2009
SOURCE:
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
Kitchen aid 2-slice toaster stopped working. It is plugged in to a good outlet.
The wiring is probably the problem. Check the connections. And then the elements . It may be burned in two.
Jan 27, 2013 | KitchenAid KPTT780ER 2-Slice Toaster
I've just stuck a small hole in side of the freezer, while trying to chip away the ice that had gathered there. Stupid? Me? Chuck it out and buy a new one?
Hiya Jonathan. If it's just the plastic that there's a hole in patch it up with araldite or superior glue. If there's a hole in the tube then that will be no good and you will need to buy a new one. Hope i was of some help to you, kind regards.
Feb 11, 2012 | Zanussi Refrigerators
Paula Deen toaster egg poacher caught on fire
The same thing happened to me today and I've been searching the internet for other complaints. It happened exactly as you said, I heard a buzzing noise and went to see what it was and it was the toaster- smoke started to come out from the top. Please report your experience to the CPSC! http://www.cpsc.gov/index.html This thing needs to be recalled!
Jul 04, 2009 | Back to Basics TEM-500 Egg & Muffin...
I have enjoyed my egg and muffin toaster for some time but all of a sudden the heater for the egg portion is not working. Is there a part (fuse?) or something that I can purchase to get it working again?
What a coincidence! My neighbor brought over his back-to-basics a couple of days ago with the same symptom.
I took it apart but haven't completed testing yet -- but it's not going to be simple. I think it's the relay for the egg cooker. It's soldered in a circuit board -- most likely will need replacing.
Unless you have experience with appliance repair, you should probably take it to a shop.
May 09, 2009 | Back to Basics TEM-500 Egg & Muffin...
Slide button won't push down
I have the same problem, if my toaster isn't plugged in. If it is plugged in, it should work.
May 02, 2009 | West Bend 6220 Slide Thru 2-Slice Toaster
BTA320 bought today. Lever wont stay down to toast.
Since this is brand new, I would suggest return it for a new one.
May 02, 2009 | Kitchen Appliances - Others
Remington ES-1000 Electric Shaver Logo
158 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Robert McClure
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
