Found this drive in an old unit. Can I set jumpers to slave or secondary? No labels on it to show settings
  • 3 Answers
Presuming you are referring to a hard drive ,it depends on a few things , firstly when you removed this drive from the older system, was it alone or was there a second hdd presesnt, if the drive was alone ,chances are that it was a single standalone drive and is probably set as master or standalone,found this drive in an - jumpers.gif
this is a good example of a jumper configuration on an older type [6 pin] ide interface hard drive, in my experience of these drives , to generalise ,
1 + 2 = master or single
3 + 4 = secondary
5 + 6 = cable select
if you follow this example and set the jumpers to 3 +4 ,on a working bootable system then you should be able to access the data from the other drive when your os has booted, if your system fails to boot check your boot sequence in the system bios is set to the correct drive , then restart the system, other than this, the best advice i would give is to experiment with differrent jumper shorts also try removing the jumper completely,
and always remember to turn the computer off ,unplug it , and earth yourself by touching the pcs case , every time you have to change anything within the pc,
i hope this has helped
please leave feedback if so
anthony !
Posted on Apr 07, 2008
How do I slave a cd-rom drive in a dimension 1100
Most CD or DVD drives installed in modern computers have a group of short jumper pins on the rear of the drive that determine the master or slave setting for the device. The master or slave setting helps to identify the drive when it shares a connector cable inside the computer with another device, such as a hard drive or even another optical drive. Without the master or slave jumper setting, the computer would not be able to tell one device from another or from which drive to retrieve or write data. Configuring a CD drive as master or slave is a relatively simple task that takes only a couple of minutes.
Turn the CD drive so that you view the rear of the unit, then check the position of the jumper covers on the set of pins next to the power adapter plug. If the CD drive will be the only device on the IDE data ribbon cable, set the jumper cover on the two pins farthest away from the power connector. This position is the master drive setting, and, by default, most CD drives ship with this configuration. In most cases, if the CD drive is the only device connected to the cable, you do not need to change the jumper setting. Determine if you need to change the CD drive jumper setting if the device will share a connector cable with a hard drive or another optical drive. If the CD drive will be the primary (master) device on the cable, do not change the jumper setting. If the CD drive will be the secondary (slave) device on the cable, continue to the next step to change the setting. Use a pair of needle-nosed pliers or your fingers to remove the jumper cover from the CD drive if the unit will be the secondary device on the IDE ribbon cable. Set the cover over the pair of pins next the pair from which you removed it, then press it until it completely covers the pins. The jumper is now in the slave setting position.
Mar 02, 2013 | E-Machines T2892 PC Desktop
Tip
How To Upgrade Your Own PC Hard Drive
At this point, the computer is powered off and I'm ready to add the new hard drive as a second hard drive. Since there is only one hard drive installed at the start of the upgrade, the old hard drive is already installed as the master hard drive on the first IDE cable. The new hard drive is added as the slave hard drive on the first IDE cable (the same IDE cable as the old hard drive, but using the slave IDE connector).
The first step is to set the jumpers on the back of the hard drive into the slave position. These pictures show the back of the hard drive which also contains a label indicating what each jumper settting means.
To get a close-up in which you can actually read the jumper label in the picture, I've taken two separate close-ups of the label and placed them side-by-side with the first showing the left-hand side of the label and the second showing the right-hand side of the label. Clicking on any picture makes an even larger image. For details of what each jumper setting means, see this Deskstar 120GXP Jumper Description at the IBM/Hitachi Storage Technical Support site.
It can be confusing to know how to set the jumpers just from looking at the label. As you read across the left-hand and right-hand pictures, you'll notice that a setting for "DEVICE 0 (MASTER)" appears twice. Same for "DEVICE 1 (SLAVE)". But the first mention applies to "16 HEADS" and the second mention applies to "32GB Clip". The Deskstar 120GXP Jumper Description does a good job of clearing up the confusion, so rather than repeat it here I'll just strongly recommend you give it a look.
Here are links to jumper information for other popuplar hard drive manufacturers. Western Digital Jumper Setting Information Maxtor. Once there, click on the particular hard drive model. Then select "Jumper Settings" and/or "Jumper Guide" in the [Technical Specifications] field. Seagate Jumper Setting Information. Look near the bottom of the page.
The default, shipped, jumper setting for the IBM Deskstar 120GXP 80GB jumpers is in the "16 HEAD", "DEVICE 0 (MASTER)" position and this is how mine arrived. Here's a close-up showing the jumpers circled in red. The IBM Deskstar 120GXP 80GB hard drive has nine jumper pins and two jumpers. The jumpers are white and rectangular in shape and are shown inserted over two pairs of pins. Notice the pins covered by the jumpers match the jumper label diagram as shown in the side-by-side pictures for "DEVICE 0 (MASTER)" next to "16 HEADS" . This is the correct jumper setting to use for the hard drive after the hard drive has been cloned and it is ready to become the Master hard drive.
But at this point in the hard drive upgrade procedure the new had drive is being added to my computer as the slave hard drive. Although the jumpers are small, you should be able to use just your fingers and move the jumpers such they are set into the slave position. In my case, that means setting them as shown here. Again, it can be confusing because the same picture shows, and right above the jumpers themselves, a jumper diagram labeled "DEVICE 1 (SLAVE)" which shows a different jumper setting. But that "DEVICE 1 (SLAVE)" jumper setting is for "32GB CLIP". Some computers (i.e., older computers) cannot use the whole 80GB and this jumper setting "clips" the hard drive down to a 32GB slave hard drive. My computer can use the full capacity of the hard drive. You'll notice the jumper positions in this picture match the jumper diagram for "DEVICE 1 (SLAVE)" next to "16 HEADS" shown in the previous side-by-side pictures.
Not all hard drives have the same jumper options and labeling as the Deskstar 120GXP. For example, here is a Western Digital WD1200JB (120GB) hard drive. Notice that the labeling is on top of the hard drive rather than on the rear. In addiition, there is only one jumper since the Western Digital does not support re-configuring the number of heads in the drive or the total size of the drive.
Hard Drive Upgrade Install Guide
The hard drive has holes on the side which are used for the mounting screws as shown here. Like most hard drives, the IBM Deskstar 120GXP 80GB has places for 6 screws, three on each side. On the IBM Deskstar 120GXP 80GB hard drive (and this was also true for my old IBM Deskstar 75GXP 45GB hard drive), some screws could be longer than others. In fact, three of the six screws could be longer since they had more clearance to the hard drive itself. For my hard drive upgrade and install, I used a total of six round-head machine screws, size 6-32. Three of the screws were 1/4 inch in length and three of the screws were 3/8 inch in length. Click on the picture to see it enlarged.
Here's a picture taken inside My Super PC before the new hard drive is installed. The case I use, the Antec KS-282, holds the 3.5 inch drives such as the hard drives inside a "drive cage". The drive cage is handy since it makes installing the hard drives a little easier. This picture shows the drive cage circled in red and the old hard drive which will eventually be replaced circled in blue. Click on the picture to see it enlarged.
Here's a closer view showing the contents of the drive cage before the new hard drive is installed and still containing the old hard drive. The backside of the old hard drive looks similar to the backside of the new had drive since both are IBM Deskstar hard drives, just different models. You can see the backside of the hard drive is in three sections. The leftmost section is where the IDE cable connects. The jumper pins are in the middle. You can see the jumpers on the old drive are set in the master position, which makes sense since it's the only hard drive in My Super PC. The rightmost section is for the power connector. Click on the picture to see it enlarged.
Install The Second Hard DriveLet's look again at the interior shot. I've circled the slave IDE connector. There are three connectors on the IDE cable and they are color coded. I've circled in red the gray connector on the IDE cable. This is the connector for the slave hard drive. The master hard drive connector is black and is still plugged into the old hard drive in the drive cage. The connector on the IDE cable which connects to the motherboard is colored blue. Click on the picture to see the picture enlarged.
The new hard drive will plug into this gray connector as the slave device. And you'll need a free 4-pin power connector like the one shown to connect the new hard drive to the power supply. Click on any picture to enlarge it. Like many things that connect inside the computer, both the IDE connector (the gray one, in this case) and the power connector are "keyed" by their shapes or some other means so that they cannot be plugged in "upside down". For example, if you enlarge the picture of the gray connector it's easy to see that the center of the connector includes a plastic bulge and a blocked out pin receptable to prevent it from being plugged in incorrectly.
This picture shows the backside of the hard drive where the connectors plug in. There are three sections on the backside of the hard drive. The leftmost section circled in red is where the IDE cable connects. The jumper pins are in the middle. The rightmost section circled in blue is for the power connector. Click on the picture to see it enlarged.
on Jun 29, 2010 | Computers & Internet
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
How can I detect maxtor 3200 ide as slave
Somewhere on the harddisk, you should be able to see a label indicating jumper settings. Check that the jumbers are set to slave sattings.
Dec 17, 2008 | Maxtor DiamondMax D540X 100 GB ATA-133...
Old maxtor harddrive
Most Maxtor Drives have jumper setting so that if "Jumper 50" is set; the two pins farthest from the power jack, is Master Drive. No pin jumper set, Slave or Cable Select. I hope this helps.
Aug 30, 2008 | Quantum Fireball Plus AS (QMP20000AS-A)...
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
How to set hard drive jumpers
a common hard drive jumper setting if its an ide sata, when you look behind the hard drive, you can see there are 4 places where you can set the jumpers...
there is cable select which you dont havce to put any jumpers at all. there is slave to which you may put 1 jumper there. and there is also master which sometimes is a single drive. any indication should be seen there above the jumpers which is indicated as MA- master, SL- slave CS - cable select.
hope this helps you in some way.
May 04, 2008 | Computers & Internet
Harddisk
Check the jumper settings on the back of the drive, if this is the primary HD, set it to master, if secondary, set it to slave, if secondary still does not recognize, switch the ide cable so that the two drives are not on the same one.
Nov 19, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
