Question about Hunter Low Profile III 20807 Ceiling Fan
Hunter ceiling speed.
Hunter ceiling fan will only run on high. The pull chain is operational, but does not change the speed nor turn it off.
  • jansson84 Jul 06, 2008
    Low profile ceiling fan only runs on high. Installed more than 20 years ago. Love it since it's quiet, but not when it only runs on high. Is it merely a switch repair?
    Problem Solver:
  • 8 Answers
A fan that old has a muilti speed capacitor. It could be that or the swicth. First thing to do is test the swicth with a voltage tester to see if power is switched to different posts if it does switch it is prob. the cap. Good luck trying to find one.
Posted on Dec 26, 2008
My hunter ceiling fan turns very slow
Check your capacitor. If this is an add on remote, set the fan on high with the remote then pull the chain on the fan until you get high speed.
Sep 17, 2014 | Hunter 52" Ceiling Fan With Light And...
How to sync the remote with the fan?The remote was operating the fan, but someone must have pulled the chain on the fan.
I have a ceiling fan that fails to operate under remote control whenever a power outage occurs. The solution is to pull the chain to guess which is an ON position, then operate the remote to select fan speed or off. Same routine for the light, if there is one.
Sep 04, 2012 | Hunter Fan Company 20184 H 52" Antique...
I just moved into a house with a Hunter ceiling fan only controlled with a hand-held remote controller that has 2 speeds: OFF and HIGH. How can I adjust this fan to a lower speed?
If the fan still has a pull chain on the side of the motor housing, you can use that to change the speeds and/or turn it it OFF or ON. If it has 2 chains, one is for the speed control and the other is for the light fixture, it is so equipped.
Hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | Heating & Cooling
Fan stays on high speed
How did you change speeds? Remote, pull chain or wall switch.
fanman9952@aol.com
Dec 11, 2010 | Hunter 23852 Classic Original Ceiling Fan
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hunter 3 speed ceiling fan now turns slowly
Probably a bad capacitor. What model is it? If it completely wireless (in other words: no pull chains for light or fan) the capacitor is located on the receiver for the fan (in the canopy or the lower switch housing). Unless you are handy with a soldering iron, it is easier to purchase a replacement receiver.
Apr 13, 2008 | Hunter Dryers
Hunter Low Profile III 20807 Ceiling Fan Logo
576 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
