Question about RCA 27V520T 27" TV
Set won't stay on
I have a RCA 27v520t. Immediately after the set is turned on it shut itself off. I bypassed the remote control and tired the on/off button on the front of the set and it does the same thing. I also noticed the set comes on then shuts off immediately when I hit the channel up button on the front of the set.
Hi im joe i have the same problem, but before this happened it turned the channel by its self and hade a mind of its own. to get it on unplug it. then as you plug it in repeatedly press the power button on the REMOTE. this will get it to turn on. if you get it on and some how get to control it then go into menu and put the fpd lock on. now you can only use the remote but at least it works. :)
Posted on Oct 16, 2008
How do I find Colby tv codes to program into a rca converter box remote
RCA converter box remote control have no set-up code to Coby.
Feb 28, 2015 | RCA Televison & Video
Just bought a used older model rca tv parental controls locked. any master codes to bypass parental control
If you forget your password, press and hold TV on the remote and the
MENU button on the television
simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
Jan 03, 2011 | RCA 27V520T 27" TV
RCA TV changes channel and volume, and shuts off by itself.
ok its not a cap problem.. memory ic problem...u have to replace memory ic the nos are i think 24c16 or24c08
u have to buy the memory by giving ur model no of the tv
Mar 06, 2010 | RCA 27V520T 27" TV
See below
Press and hold the desired device key - TV, CABLE, or VCR - until the red light stays on. Turn on the corresponding device and press the remote's POWER key repeatedly until the device shuts off. Press STOP and the code will be stored.
May 21, 2009 | RCA Universal Remote Control
Television turns on and off, turns up volume and changes channels
Hi
Replace all tact switches at the control panel... all switches is have bad resistance thats why your system is abnormal!
Thanks!
Feb 24, 2009 | RCA 27V520T 27" TV
RCA 27F520T TV
Models: 24V511T, 24V510T, 27V512T, 27V513T, 27V520T, 27F520T, 27F50T, and 27F634T
TOPIC: Set comes on by itself
Symptom: When the set is first plugged in or after a power interruption the set comes on
Cause: Set was not taken out of factory mode, or has returned to factory mode
Cure: In the service menu go to setting FAC07, then change the value of OPTM2 to “00”
To enter the service mode simultaneously press “Volume Down” on the front panel and “Info” on
the remote control.
Use the original TV remote for the instrument.
Press “7” on the remote to enter factory menu 07. Use the channel down button to scroll down to
OPTM2, then use the volume buttons to set the value to 00. Press the “Sound” button on the
remote to exit the factory mode. DO NOT turn the set off until the screen displays “OK”.
Sep 12, 2007 | RCA TruFlat 27F520T 27" TV
Shuts down
it is due to problem in red cideo section. solution 1 supply to red video output& output itself 2 crt base loose 3 connector loose 4 red video sigal line from chroma ic to red cathode of crt. 2 red
Nov 13, 2006 | RCA 27V520T 27" TV
Televison & Video Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
