Question about Sony RDR-VX555
Recording from dvr to vhs
Describe your problem
When recording from dvr to vhs , tape records in black and white. Doesn't happen w/dvd.
  • wicked1woman Jun 02, 2008
    Attempting t
    same problem. dvd-r (vr mode) and dvd-r (video mode) both dub to vhs in black and white only!
  • 105 Answers
Check/replace the cable from DVR VIDEO OUT to VCR VIDEO IN
Posted on May 03, 2008
Recorder stops recording from vhs tapes after about a minute
Some VHS tapes have copyright signals embedded in them. Then when the DVD recorder reads the copyright signal it will stop recording due to it thinking there is a copyright violation happening. Try testing with a VHS TAPE of a show you have recorded off the TV and see if it does the same thing .,
Mar 24, 2016 | Televison & Video
How do I copy(to DVD) my SVHS tapes using my JVC MV-40
It all depends on what kind of connections you are using. In most cases you set the dvd recorder to input 1. Then use the yellow,red & black or white out puts from the vhs player to hook up to the number 1 input on the dvd recorder. hit play on the vhs & record on the dvd recorder at the same time. Do not forget to put a blank dvd in the dvd recorder? also for the best copy set your dvd recorder to XP for a 1 hour recording for a 1 hour or longer recording set the dvd recorder speed to SP. You should have the dvd recorder hooked up to a Tv so you can monitor the recording progress. This should work out as long as the recording you are copying is not copy protected. Good luck.
Feb 07, 2015 | JVC Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
When recording from vhs tape, and the signal is poor at times, the machine automaticaly stops recording temporarily and resumes when the signal is more stable. how can this feature be disabled?
If you are recording VHS tapes that contain macrovision, and most commercial tapes do, you can't record them with this DVR because it is compliant with the law that says you can't do it. So don't try. Download nearly every movie/tv show from the internet instead.
If you are recording from VHS tapes that you have created yourself from TV sources, or from camera, you must stabilize the picture. There are several devices like that. Do a google search on "vhs stabilizer".
Apr 21, 2009 | Protron PD-DVR100 DVD Recorder
How to switch the tape speed on Go Video dvd/tape.
  1. Press SETUP,
  2. Toggle with the left/right arrow to the RECORDING OPTIONS (icon has a dot and the letters REC below it in the icon menus at the top of the set up screen.)
  3. While RECORDING options is selected, press the DOWN arrow to select VCR RECORD QUALITY.
  4. Press ENTER to go to the submenu.
  5. Use the ARROW UP/DOWN buttons to select the desired quality.
  6. Press ENTER to confirm selection.
  7. Press SETUP to exit the menu.
This is the same procedure for selecting the quality for the DVR recording speeds.
VHS speeds are:
SLP is 3x the recording time of SP.
DVR recording options are:
HQ=1 hour
SP=2 hours
EP=4 hours
SLP=6 hours
per disc.
Mar 18, 2009 | GoVideo VR3845 DVD Recorder/VCR
Will not record on a DVD R
what I would do is play the vhs tape for a bit then rewind and press the dub botton only and see what happens. if nada then insert a new blank dvd and make sure its formated.
Apr 05, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Pioneer dvr 225 recorder
the dvd recorder has to be set to monitor the program your watching! you can not copy vhs tapes to dvd this way because the tapes that are prerecorded have a copy protect feature and will nut copy right!
Dec 15, 2007 | Pioneer DVR-225 DVD Recorder
Sony RDR-VX555 Logo
229 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
