13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on
or when the top door was closed. Action: 1.
Open top cover and remove toner cartridge. Remove all media in the
paper path, and then re-install toner then open and close the top cover. 2.
Open read door and pinch blue latches on fuser and pull it out.
Inspect the sensor flag for correct movement and any paper obstructions in the
fuser rollers. Re-install fuser and Confirm rear door closure. 3.
Remove tray 2 and confirm paper is not jammed in the pickup area.
Confirm paper size adjusters in the tray are correctly set for paper being
used. (Do not set back paper stop to ANY) 4.
Replace any defective sensors or flags Hope this helps. Please keep us updated and
remember to rate this answer. TF
13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on Action: 1. 2. 3. 4. Hope this helps. Please keep us updated and TF
Thank you for contacting FixYa with your printer inquiry.
This error message prompts when paper or obstruction holds a
sensor switch or toggle open in the paper path. Paper can jam a sensor and make
it think there is a jam when there isn't one.
Action:
It's possible the fuser has been changed out and the
incorrect replacement has been installed. You will want to confirm the part
numbers if so.
If the DC Controller has been changed you will want to
confirm connections.
Hope this helps. Please keep us updated and remember to rate
this answer.
TF
