you can unlock your Blackberry PEARL 8100 eaisly with Blackberry Imei Unlock code. first call your service provider ask your Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry Unlocking Codes. Buy your unlock code from third party. i hope this information is help you :)Good Luck
you got to make shure your mic was instaled properly if it was part of the old housing you must put it into the new one if your mic is on the board itself check to see if you damaged the headset plug this is a problem people forget how sesistive these electronics are any slip of the hand can remove several parts of the board and you wont be able to see the damage its cheaper if you get someone that knows how to handle such sensitive equipment if you cant solve your problem chances are you ruined you phone good luck!
there is one of two issues that causes this:
1. backup your pearl with your desktop manager and then perform a wipe handheld in your options menu. then restore your pearl and see if that works.
2. if that doesn't work, the back housing of your pearl will need replaced. you can find them on the internet somewhat inexpensive. and with the right tools, it is a quick and easy repair. there are video tutorials on how to open your pearl on youtube
Blackberry can be unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party, both are safe way to Unlock your Blackberry Pearl 8100.when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:) Best of Luck.
There can be many ways to Unlock your phone.As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry 8100 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
