Question about Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher
Kenmore 587.1616 - upper sprayarm doesn't move -
Hi, trouble with upper sprayarm... tried most everything.
a). no obstructions/blockage of sprayarm
b). cleaned out base (gook removed), could not actually get to chopper... but got to rotating axle
c). pressure to machine okay... (not sure about top)
d). roof entry of water aligned with funnel water intake (activating upper spray arm)
e). worked fine recently
f). used high power hose (outside) and sprayed right into sprayarm... did not rotate (although it was free to do so ... this confused me)... water just dribbled out... yet no known damage to spray arm.
any ideas? got to area of chopper but did not get to actual rotating blade. pulled out lots of hair! but chopper axle does freely rotate by hand.
any ideas? had to ask the guru... thanks so much in advance. pete
Remove chopper, clean screen on chopper.
Posted on Nov 23, 2011
Hose doesn't have suction
Hi Danny,
I am sorry to hear you are having difficulty with your DC18. I understand you have checked for obstructions, however, the problem you are describing sounds like a blockage. Please click on the appropriate link below to view step by step instructions on how to locate and remove a blockage in the wand, hose and the hose inlet. If you prefer we would also be happy to walk you through these checks over the phone. If the problem persists after the recommended trouble shooting steps have been carried out, please call us directly as your machine may need to be serviced by an authorized Dyson technician.
Link to Dyson support page US:
http://content.dyson.com/support/help.asp?article=1049&product=DC18-ALLFLOORS
Link to Dyson support page UK:
http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
If you determine you need further assistance, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (US).
Best wishes,
Jessica
Dec 11, 2012 | Dyson DC18 all floors Bagless Upright...
Won't drain completely
Check the inlet to the pump for blockage, make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe and that the pump is actually operating. Check the filter to see if it is not clogged or obstructed. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jul 09, 2011 | Kenmore Dishwashers
Upper tray of Kenmore 13742 is not cleaning. Followed the Versastyle fix for rmussak on Mar 6,2009 to determine if chopper or motor needed replacing. Everything seems fine. What next?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Mar 11, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
We have a Frigidaire dishwasher model #FDB634RF bought new. It was used for a not very long period of time but developed problems due to well water with high lime content. now with good cleaning products...
heatman101
Jul 03, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Suspect blockage top rotating washer arm does not spin
Both arms (upper and lower) are fed from the back of the machine, when you close the door the arms make a water tight seal with the pumped water in your washer.
Check to see that when the machine is full that both the arms will turn with very little pressure. (watch out for forks sticking out of the cuttlery tray etc.)
You can usually clear a blockage by putting a bag over the back of the arm that engages with the pumped water on the arm that "IS WORKING" this will increase the pressure to the arm that is not working usually freeing the obstruction.
Nov 07, 2009 | Kenmore Dishwashers
The upper sprayarm flows water but does not turn. Therefore dishes in upper rack are not geting cleaned.
i have a kenmore elite dishwasher model 665.16059400, i need a lower spray arm nut, nobody can find this part, i've been to sears and also to their on line parts department 3 times and have come up empty, the last time i was assured that the nut would be included with a new spray arm if i ordered one, it was not,i know the spray arm was made by whirlpool, is there anyone out there who knows the solution to this simple problem? does whirlpool have a cross referance model number i can use to find this part
Apr 29, 2009 | Dishwashers
Washer problem
Inspect the drain hose, see if there is any obstruction.
Try to understand if the machine does not drain at all or if the cycle is not completing , and timer stops before completinc cycle.
If the machine is not draining, then, once you check the drain hose and see no obstruction in there, it can be a faulty drain pump, or a faulty water level switch. If machine instead does not complete the cycle, it is a faulty timer/programmer.
See here for more detailed explanation: It won't drain
Sep 08, 2008 | Kenmore 22422 Top Load Washer
Hose Collapses When I Try to Use Wand
Hi Both.
Ok you have A blockage, Remove flexi hose completly from rear of machine & completly remove wand & handle from the hose.
Now check flexi hose for obstruction if none present move on to the wand & hanndle look down through tha wand for any obstruction look very carefully where the plastic handle meets alloy tube there is A slight bend here often A coin gets stuck here & flips accross to block oppening when you try to use wand.
If you cant see anything coin etc put hose back on machine & switch on there should be good suction from the flexi hose,
Now with machine still switched on push alloy pipe back on if the hose suddenly pulls back & there is poor or no suction you definately have A coin stuck at the bend.
You will need A broom handle or other long solid pole to hit it out.
http://dysonmanuals.llc.nu/
Aug 03, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher Logo
149 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
