Question about 3M MP 8640 Multimedia Projector
Projector lamp will not power up - 3M MP 8640 Multimedia Projector
  • goodisonhero Apr 19, 2008
    projector light dim - all lights green-can't get projector to receive image from laptop. help
  • 563 Answers
Check previous posting
Posted on Apr 07, 2008
6ya staff
SOURCE:
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
Red warning light
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
How do I reset the Lamp timer o an NEC MT1050 projector... Without the hand held remote control?
On some Projectors that I used to service, Holding the power button whilst plugging into power did a lamp timer reset. ( Of course check the lamp is fully seated and the lamp door is closed
Feb 24, 2011 | NEC MT850, MT1050, MT1055, MT1056...
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
How do you change the bulb?
Hello :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
Here are the steps that explained in the manual :
Lamp Replacement Procedure:
1. Switch off the power to the projector by pressing the Power/Standby button.
2. Allow the projector to cool down for at least 30 minutes.
3. Disconnect the power cord.
4. Use a screwdriver to remove the screws from the cover.
5. Push up and remove the cover.
6. Remove the 2 screws from the lamp module.
7. Pull out the lamp module.
PLEASE RATE !
Apr 13, 2010 | Optoma EP747 Multimedia Projector
I press the power on and the lamp led not the
Hello :
Try to change the bulb .
Here is how :
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
please rate !
Apr 12, 2010 | ViewSonic PJ458D Multimedia Projector
InFocus LP130 Projector has intermittent power off
go into the menu to find out the lamp hours. it could be the lamp, but if the projector shuts down and not just the lamp, there is either an overheating issue, or a power supply issue.
Mar 07, 2009 | InFocus LP130 Replacement Projector Lamp -...
3M MP 8640 Multimedia Projector Logo
48 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Lampdeng.com
Lampdeng.com
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
