Question about Danby DPAC9030 Air Conditioner
Danby dpac7008 portable air conditioner
I want to know how these portable air conditioners are supposed to be set up. Do they have to be on the same as the window out of which the hose goes?  If the window is 4.5 feet off the ground, does the air conditioning unit need to be put on a table to make it and the window on the same level?
  • Anonymous Jun 22, 2008
    I have cleaned the screen and allowed proper drying time, filled the resivour on the back and inserted a drain hose to get my unit to work more than it's typical 6 hours. My question is am I suppose to have both of the plugs attached to a drain hose? Both plugs when unscrewed release water abundantly. This has just started to happen as my unit functioned properly for an entire calendar year previously. I need some support as I think I have done all that was asked of me as a consumer and I am a 82 yr old that requires some cooling off in this heat.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
To the best of my knowledge the unit can stay on the floor and included the product features listed below and it does have a dehumidifier reservoir with direct drain and to make sure if you use the drain hose that the hose is higher than the item that you are draining the water into or you can elevate the unit so that the hose can drain outside and out the window - but you can also drain the water into a bucket or some thing that will hold water. I hope this will help you…..
Product Features
danby dpac7008 portable air conditioner - picexporterror From our expanded online assortment; not available in all Best Buy stores
picexporterror 7,000-BTU cooling capacity lets you cool rooms up to 250 sq. ft. picexporterror
Electronic temperature controls let you adjust the temperature in 1° increments fodanby dpac7008 portable air conditioner - picexporterroroling; 3 fan speeds
picexporterror Dehumidifier mode removes up to 45 pints of modanby dpac7008 portable air conditioner - picexporterroro 24 hours; 6.3-pint dehumidifier reservoir with direct drain
Auto on and auto off timer
picexportdanby dpac7008 portable air conditioner - picexporterrorh_mi Overload protection helps protect the air conditioner from power drains and surges
Mesh filter is removable for quick and easy cleaning
picexporterror Includes remote
Posted on Apr 15, 2008
    New Friend:
How do u turn on a silhouetto dandy floor air condition
Posted on Sep 04, 2010
6ya staff
SOURCE:
I bought a danby portable air conditioner DPAC7008 yeaterday. Got ready today and plug it in, but the red light keeps flushing and the screen shows P1 continuously, it does not start. I checked the water...
Hi, and here is what you need to do. Take it back and get one that works correctly!. This happens to many times as straight from the factory they come and will have problems before you have a chance to do anything. Before I would walk you through any trouble-shooting steps, I would ask you to take the time to exchange it so you don't mess up the warranty. Get a different one and be done with it.
Sincerely, Shastalaker7
A/C, & Heating Contractor
Aug 31, 2010 | Amcor PLM-14000E Portable Air Conditioner
My danby portable air conditioner won't turn on
New or used? Is is plugged in? Is there electric at the plug? Plug a light in there and make sure it works as a test. Next, check the water pan to make sure it is not full of water. There is a switch there that could be causing the problem.
Jul 06, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
The blue light keeps blinking and error e04 comes up
I have a DPAC 1200068 air conditioner and the red light keeps blinking and I need to know how to shut it off so it flashes when it is suppose to and go off when it is suppose to.
Jun 21, 2010 | Danby Portable Air Conditioner
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
Danby portable air conditioner does not cool properly. what do I do?
what temp range are you working with here? are the filters clean? we need to know what Air on temp is and Air off temp.
Jun 24, 2009 | Danby Portable Air Conditioner
Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
May 18, 2008 | Danby Portable Air Conditioner
Open Questions:
See all Danby DPAC9030 Air Conditioner Questions
Danby DPAC9030 Air Conditioner Logo
1,376 people viewed this question
Top Danby Heating & Cooling Experts
Dennis Boxerman
mintvl
Level 1 Expert
Bill Long
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
