Question about Gateway FPD2275W LCD Monitor
Dead LCD Monitor
Hi Experts
I have a 17 inch LCD Ingram Micro Monitor. I went to turn it on and there isseems to be no power. Checked the power supply unit and that is ok, checked the power supply leads for any possible breakages they are ok.
Can you give any answer ?, One hunch I have is that it could be the inverter if so how would I get hold of one?
Many thanks
Stuart
  • Anonymous May 11, 2010
    I am not familiar with this particular unit so I will ask a few more questions:
    1. Is it mains powered or does it run from a transformer?
    2. Is there a power light on the front at all?
    3. Is there a seperate power switch on the back?
    If it's the inverter then you will still get power to the monitor and so will still have a power light. If you can also take a photo of the power board that will help a lot.
    Thanks
    Scholar:
  • 176 Answers
Check if there is power voltage in the collector pin of the horizontal transistor. If there is voltage your power supply is good in the problem maybe is the high voltage section. but if there is no voltage i think your primary power supply circuit have a problem. Try to open the pin of the plyback connected to collector of horizontal B+ and open the computer . if the light indicator on the problem is maybe the plyback or the horinzontal section
Posted on Apr 16, 2008
SOURCE:
My HP monitor was working fine then randomly one day it went dead, I turned it back on and I could see the screen and what it displayed for about 2 seconds, then the screen dies again. The power button is...
Sounds like your monitor is going dead. If its under warranty that would be the best way to go. Specifically it sounds like the power inverter is dead or there is a busted capacitor.
Mar 12, 2011 | HP Pavilion F1703 17" LCD Monitor
My phillips 42 inch lcd tv just went pop / bang and the picture disappeared - its now dead with no light - checked and replaced fuse
The power supply board is dead.That the board,where the power a/c cord plug in to it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 14, 2010 | Philips 42PFL5332D 42 in. LCD Television
Monitor light is green but display is black
your power supply board, probably has some bad caps in it
Jun 12, 2010 | AOC LM729 17" LCD Monitor
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
I have a NEC lcd1765 monitor that is dead!
Hi...there,
No power...usually caused by burnt out capacitors in the built-in power supply with inverter.
Dec 06, 2008 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Dead monitor dell e173fp lcd monitor
This could be either down to an internal fuse blown or the main board or the capacitor on the power supply could be faulty.
jonno
Sep 04, 2008 | Dell E173FP 17" LCD Monitor
Monitor Ingram Micro 1770 A/Mg 17" TFT-LCD
hey dude i have the same monitor the best resolution is 1280X1240 @ 60HZ
hope this helps
wez
Aug 08, 2008 | Ingram GeForce 2MX (32 MB) Graphic Card
Monitor dead
The monitor has a bad circuit shorting out it's power supply. Could also be faulty electrolytic capacitors in the power supply.
Good luck.
Aug 01, 2008 | HP Pavilion F1703 17" LCD Monitor
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
80 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
