Question about RCA P52926 52" Rear Projection Television
Picture on proscan television needs adjustment. what type of tool is needed for the adjustment areas?
  • stubbyone May 11, 2010
    in the long run can a lay person w/ sum techical know how adjust the set?
  • RCA Master
  • 8,617 Answers
That depends on what youre trying to adjust. G2 requires electrical meters, focous to be done properly needs an NTSC signal and convergence other than user menu would require screen jigs for alignment. What are you trying to adjust and include your model number and I will try and help you out
Posted on Apr 07, 2008
What audio out cord needed for proscan television.
Without a model number or picture I cannot tell you what you have available. That being said, you should have an audio left and right which will be RCA type connections. The other audio, not commonly used by home owners yet is the digital audio out. Either will work just fine.
Nov 29, 2015 | Proscan Televison & Video
I have 39 inch proscan model plded3996a and the picture is flicker everything else work fine
Flicker to picture can be adjusted. To some sets, you have to adjust it at its main power supply regulator section [there will be flicker adjustment preset]; and to some others, you have to enter its service mode option to adjust this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the phrase 'Flicker adjustment' or "Flicker" in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 31, 2015 | Proscan Televison & Video
I need to know how to adjust the picture on rca proscan tv model PS31122
Adjust via the menu in the set, this is an older model and pretty easy to work with.
Let me know if you have some issue or problem
Mar 15, 2012 | Televison & Video
40 in LCD Proscan TV, Horizontal pic too wide, adj?
just look at the owners manual of how to adjust the picture
Jul 23, 2010 | Proscan 42LA45H 42 in. LCD TV
What are the picture,color,tint,bright,and sharp settings because the picture quality is bad for the proscan ps27108 tv?
You would go into the menus to adjust the picture settings. Press the menu button repeatedly until you get the 'video' menu hilighted, then press the 'select' or enter or whatever button chooses, and then use the left and right arrows to adjust the settings, and the menu button to advance to the next selection.
tom
Nov 02, 2009 | Proscan PS27108 TV
The picture is to big for the screen
You need to adjust the aspect ratio.
Apr 29, 2009 | Proscan PS27113 TV
26lb30qd
You need to give a lot more information about the type of set-up you are using with your television. The type of components in the system, like dvd/vcr receiver etc. The type of signal connection you are using to the television. Cable or satellite box or antenna. If all your connections are correct and you are using the remote control correctly. You may have a problem with the video input circuits of you television and you should call for PROSCAN customer support at this telephone number. 1-888-977-6722. You can also get customer support from their website. www.oncorpus.com. I hope this has helped you with your problem.
Mar 10, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Has a proscan 26lb30qd with no picture.
You need to give a lot more information about the type of set-up youare using with your television. The type of components in the system,like dvd/vcr receiver etc. The type of signal connection you are usingto the television. Cable or satellite box or antenna. If all yourconnections are correct and you are using the remote control correctly.You may have a problem with the video input circuits of you televisionand you should call for PROSCAN customer support at this telephonenumber. 1-888-977-6722. You can also get customer support from theirwebsite. www.oncorpus.com. I hope this has helped you with your problem.
RCA P52926 52" Rear Projection Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
