Question about Ariston Technologies CBC96 Wine Cooler Refrigerator With Ice Box
Ariston fridge fridge not cooling and the freezer is working fine
  • 2 more comments
  • zino2 Apr 08, 2008
    thanks for the solution you sent me but the fridge i got is ariston freezer on the top small and fridge at the bottom wich is not cooling and the freezer is working fine can you help? thanks
  • zino2 Apr 09, 2008
    thanks for the advise i will let you know what happen,thanks again
  • Anonymous Nov 03, 2008
    ariston fridge freezer model number MBA 3842C
    THE FREEZER IS WORKING BUT THE FRIDGE IS NOT COOLING AT ALL.
    ALL HELP GRATEFULLY RECIEVED
    THANKS
    RIC
  • Anonymous Feb 25, 2009
    Hi there...My fridge also stopped working at I have tried all the functions. My freezer is working fine with no problems but I realised that my fan in my fridge stopped working.
    Can you maybe send me a wiring diagram of the fridge so I can check the cable, I believe there must be a loose wire cause sometimes it comes on when I move the fridge.
    Thank you.
  • 236 Answers
Try to defrost the unit, if it wont work check the air vents if air is present. Check also if some of your stuff may be obstructing the air vent.
Posted on Apr 07, 2008
  • 1 more comment
  • Felizardo Erilla
    Felizardo Erilla Apr 09, 2008
    Check your setting temp. at frige.
    Refrig. compartment
    When the appliance is switched on, the refrigerator
    compartment is brought to the standard setting of + 5°C.
    We recommend you enable the SUPER COOL function to
    speed up the cooling process of the compartment: after a
    few hours, you may place food inside the refrigerator.
  • Jennifer Bagwell
    Jennifer Bagwell Oct 11, 2013
    this is exactly what my fridge display looks like but it keep flashing, does not store the time after you have reset and sometime the fridge is not very cool
  • Christian Odehnal
    Christian Odehnal Sep 05, 2014
    @ Jennifer Bagwell: Did you ever figure out what was causing it? Because I have the same problem right now :(
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
The evaporator fan is blowing the freezer works fine but the frige don't,?? what else can i check?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Hotpoint-Ariston HSS22GFTWW (22.0 cu. ft.)...
EL7ATRR Refrigerator: Freezer working fine but fridge not cooling...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 17, 2010 | Whirlpool EL7ATRR Refrigerator
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Ariston Fridge not cooling - Frozen Coils
Try to check the noisy fan, slow rotation of fan can cause the icing evaporator. Unplug the unit and rotate the fan manually by your finger check if the fan is not misalign or not touching the fan frame. Or check if fan motor bearing is not worn out. Under charge of gas is also one of icing cause.
Feb 20, 2008 | Ariston Technologies CBC96 Wine Cooler...
The fridge is not cooling but the light turns on and the freezer is fine
Thank you sir even i had this problem.Its working properly now!By the way sir i have a few more questions that i need to get clarified can u help me with them?
Oct 23, 2007 | Ariston Technologies CBC96 Wine Cooler...
Ariston Technologies CBC96 Wine Cooler Refrigerator With Ice Box Logo
1,728 people viewed this question
Top Ariston Technologies Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Ariston Technologies Refrigerator Expert? Answer questions, earn points and help others
