NetGear WGR614 Wireless Router Logo
A
Anonymous Posted on May 20, 2010
Router is not able to make wireless connection. Wireless light is off
Anonymous
Level 3:
  • Master 1,272 Answers
  • Posted on Jun 09, 2010
Anonymous
Master
Level 3:
Answers
1272
Questions
Helped
385047
Points
3713
I would suggest you to reset the router by pressing the reset hole on the back panel of the router for 10 seconds. Then please reconfigure the router and you will be able to access internet wirelessly
3answers
Can't find mg3600 on register list ?
http://ugp01.c-ij.com/ij/webmanual/Manual/All/MG3600%20series/EN/AFG/afg_webprint3.html
Apr 03, 2018 • GPS
Wifi connection
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel.
2. Analogue video senders used to send audio and video to other TVs in the home.
3. Microwave ovens emit interference in the 2.4GHz band.
4. Wireless speakers and console controllers can cause interference with the wireless router.
5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem.
6. Power cables located near the wireless router can cause dropouts and speed reduction.
7. Fish tanks and mirrors will cause massive Wi-Fi shadow on the other side of the tank from the wireless router.
8. Depending upon the location of large mirrors will reflect wireless signal away your computer.
9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances.
10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Wireless connection
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Wi-fi distance of beetel 450tc1 adsl2+router
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the other sideof the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Wireless router routinely drops connection with Macintosh?
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Trying to connect my ipad 2 to wi fi via belkin surf n 300 wireless router put password in and message camesup "unable to join the network "Belkin.361B"
Before you start :
Make Sure the Wireless Switch on your Computer is turned Off (If you are using a laptop to connect to the router )
Make sure that the Light on the Router is Solid Green
Step 1 : connect a computer to the router (Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
I cannot connect my IPOd Touch to the internet to download music . I need wi-fi connection. I already have internet service. What is wi-fi and how do I get it?
Wi-fi is wireless internet. Wireless internet is aquired via a router that supports wireless internet. The router is connected to your modem which supplies your internet.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
