Question about Holmes Products HAP422-UC Air Purifier
Problem w/ homes air purifier hap422rc-u
There is a red light on the top of the tower w/ a check symbol with a circle around it . when i turn the unit on, it runs until i press the ionizer button and then the unit shuts down... brand new unit , brand new filters and yes i removed the bag from inside...
  • Anonymous Aug 30, 2008
    adfda
SOURCE: red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Posted on Apr 10, 2009
SOURCE: hepa filter
The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
Posted on Sep 01, 2007
  • 10865 Answers
SOURCE: I have a new (3 weeks) Holmes air purifier. After
Actually, your purifier is working as it should. The black soot is due to the negatives ions which attach themselves to the smoke/dust/dirt particles in the room and make them drop to floor. If you don't smoke it won't be much of a problem. Some minor residue will be found in and around the unit but this comes about because the negative ions make dust and other particulates fall to the floor. A quick wipe or vacuum easily eliminates this problem. Besides, I would rather have them on the floor than floating around in the air, wouldn't you?
Posted on Apr 26, 2009
  • 114 Answers
SOURCE: Red light on...
the unit probably needs to be reset. cause what's happening is that it's not recognizing that the filters are clean. there should be a tiny pin hole at the top of the unit. when the unit is on you need to put a small needle in there and hold for about 5 seconds and the unit should reset. if that doesn't work please please let me know and i will see what else we can do.
Posted on Aug 23, 2009
  • 3 Answers
SOURCE: i need an ionization wire for my ioninc breeze
Any system using electric currents are deadly OZONE producers if your ozone producing machine is broken pleas don't fix it replace it look for any system with a filter not a electric current burning all the dust
Posted on Jun 30, 2010
Reset oreck XML professional
The reset button is power button,look at what it says under cell check button, hold(symbol) button t reset.
Jan 27, 2013 | Oreck XL® Air Purifier
I have 4 units and all of them at the same exact time without any warning like hissing..the red light turned on. When I removed the inside part it looked like paper had caught on fire. In fact its like...
The trouble began in 2003 when Consumer Reports magazine published a report claiming the expensive air cleaners don't clean air. The magazine later claimed its tests showed that Sharper Image's Ionic Breeze Quadra Silent Air Purifier and four other units also release potentially unhealthy levels of ozone.
Read more: http://www.consumeraffairs.com/news04/2008/02/sharper_image.html#ixzz0VATFAuRq
Oct 27, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Red light on...
Mar 12, 2009 | Holmes Products HAP725-U Air Purifier
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
Red filter light still on-
ok i'm not finding that model anywhere in my system. but one way you can try is look in your manual under troubleshooting. if you have gone through all of the troubleshooting. the best thing that i can suggest is call the manufacturer. if your still under warranty they should be able to replace the unit foryou.
Nov 04, 2008 | Bionaire BAP1175-U Air Purifier
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Reset filter
The solution is simple. Just press on the little red light that says to reset filter. Its a button that will reset the warning and the light should go out
May 14, 2007 | Kaz Honeywell Tower Air Purifier with IFD...
Holmes Products HAP422-UC Air Purifier Logo
357 people viewed this question
Top Holmes Products Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Holmes Products Air Purifier Expert? Answer questions, earn points and help others
