Question about D-Link DI-624M Router (DI624MRE)
D-link di-624m During update firmware v1.20 with v2.50 , original firmware has crashed. And Even trying several time by the reset in back , I cannot access router web interface anymore.  And what is strange is the IP adress that IPCONFIG detect is 169,134.xx.xx . So impossible to goto menu . Any repair suggestions or other ideas. Thanks
    Scholar:
  • 187 Answers
169 is an internal IP. If you are not already, try a hard wired connection to the router. If this fails, you will need to get in touch with D-link.
Posted on May 25, 2008
Will this work on the imac new 21.5inch?
Yes, it works perfect. but next time but a better brand, d-link routers aren't reliable.
Regards.
Jul 26, 2010 | D-Link DI-624M Router (DI624MRE)
I bought a used D-Link wireless router DI-624M, it didn't come with the cd to download the program. I've reset it back to the default, but when I plug it in, nothing comes up. I've tried looking at the...
Well you need to log into the router and set it up.First of all if you are using dsl you will need to set it up for dsl.If its cable you need to set it up for cable.Go to the website and follow the set up instructions.
good luck
Nov 11, 2009 | D-Link DI-624M Router (DI624MRE)
DI-524 status problem
Did this happen after a firmware upgrade? If so, this link may help:
http://borgetech.blogspot.com/2007/09/d-link-di-524-revision-b4-status-light.html
Apparently there's a utility which will force firmware to load on the router. The steps are a bit technical, though.
If that doesn't work, the router is probably toast. Time for a new one.
Feb 08, 2009 | D-Link AirPlus DI-524 Wireless Router
I can't connect to wireless
looks like a firmware corruption. try running a firmware update from http://support.dlink.com/products/revision.asp
Oct 15, 2008 | D-Link DI-624M Router (DI624MRE)
Windows Vista to a Wireless DI-624 problems
I have a Toshiba Satellite connected to a Di-624m and I have the same problem.
One solution to many problems with D-Link is to ;
UNPLUG BOTH MODEM AND D-LINK.
WAIT 20 SECONDS (TWENTY SECONDS)
PLUG BACK IN AND TRY TO CONNECT.
DO NOT JUST SHUT THE POWER OFF, IT IS NOT THE SAME!
IF YOU DONT UNPLUG LONG ENOUGH IT WILL NOT WORK.
RECCOMENDATIONS:
CONNECT DIRECT WITH A LAN CABLE TO D-LINK
EVEN BETTER
CONNECT TO YOUR MODEM WITH A LAN OR USB-VERY FAST.
REPLACE THE D-LINK HUB! (LESS THAN A $100 !?!?!?)
WARNINGS-
OUR D-LINK ROUTER HAS CAUSED PROBLEMS FOR THE PAST YEAR ON OUR NETWORK, SOME OF THESE PROBLEMS WE BLAMED ON VISTA.
This wireless enviroment can corrupt downloads.
I went crazy trying to solve several download errors.
connecting direct to the hub with a lan cable solved the problem.
I have totally lost faith in this wireless system.
sorry D-link the di-264m is HISTORY soon.!
haydenshaw3
Apr 17, 2008 | D-Link Wireless
D-Link DI-624M
Looks like the file that gets downloaded has a .bix extension.
Try changing the extension to .bin
Then try the update
I think I had to do that when it first came out.
Apr 06, 2008 | D-Link DI-624M Router (DI624MRE)
Even with back reset hold for 10 sec. No reset at all
Check to make sure you're using the correct power adapter for the router. Your computer uses a 169.... address when it fails to connect to the router...this is a normal symptom when the router is not working correctly. Your router may have failed and will need to be replaced.
Jan 16, 2008 | D-Link DI-624M Router (DI624MRE)
DI-624M has "limited connecyion" perhaps due to damage to its firmware 10/20/07
          You need to upgrade the Dlink firmware,, that will do it.
Oct 21, 2007 | D-Link DI-624M Router (DI624MRE)
Forgot my password
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Forgot my password
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
D-Link DI-624M Router (DI624MRE) Logo
110 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
