Question about Maytag 20 cu. ft. Upright Freezer MQU2056B
Upright freezer my light is not working and the temp is droping. Is it defrosting its self
    President:
  • Maytag Master
  • 2,651 Answers
No light in unit??? check the bulb, reason i say that is you should aa least have lights on, check the recepticle its pulgged into
Posted on Apr 12, 2008
SOURCE:
What do OF and UL mean on temp control for ffh17f7hwb Frigidaire upright freezer?
Hello;
My name is peter. I am a retired field service refrigeration technician.
"Of" means you are locked into the defrost mode. This is where your unit will shut down every 8-10 hours. Everything will stop running except for the light. The defrost mode take about 20-30 minutes where the heater turns on and defrost the cooling coil, then the unit turns back on.
Some upright freezer have a separate defrost timer, but not yours.
Your defrost timer is built into your control board.
PART NUMBER: 297366300 - Cost: $70.00
If you go into the internet you may be able to get the board for $40.00.
Install:
1.) Unplug your unit.
2.) Ground your self by touching bare metal. Static electricity will knock out a board.
3.) With a small flat head screw driver, wedge the outer frame and pop the assembly out. You only have one connector to disconnect. You may need the small screw driver to free the connector.
Dec 24, 2014 | Frigidaire Freezers
Upright freezer orange and red light on but green light off can you advise? Frigidaire freezer.
Draw fan has failed, temp unreachable over the past cycle of 24hrs, turn your unit off for 24hrs and defrost it, restart and should work fine for a few days, if so, replace fan and defrost element only. Call service tech for this unless you are clued in on this work, not that costly.
Aug 28, 2011 | Frigidaire Freezers
I lost my owners manual. How do I defrost my upright freezer
they can be defrosted by using a blow dryer on the evaporator coil.or most common way is to remove all the product in the freezer and turn the unit off and leave the door open. most units have a defrost heater and they self defrost but if you are building up frost then you may need to check the continuity on the heating element and replace if need to. or check and make sure the defrost timer is working properly
Oct 09, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Freezer doesn't work
my freezer defrosted it self and the red tryangle light stays on what is it
May 05, 2010 | Hotpoint 4.2 cu. ft. / 119 liter Upright...
Maytag upright freezer with self defrost. The water line freezes.
This sounds like your defrost heating coil has gon bad. Not much you can do but replace it. Please leave a good thumbs up for me for the effort. Pretty sure I'm correct on this one. The Raz Shack
Mar 11, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Jun 21, 2009 | Frigidaire Freezer Refrigeration White...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Continues to run
It seems your temp. control board or thermistor is not reading the temps and just keeps on running and running. Can you lower it to the lowest setting and (with a thermometer) see if the temps actually get warmer inside (will take a day or two to warm up). As for the ice on the bottom if the drain for the defrost cycle is plugged you may be getting water inside which then re-freezes. Let us know what you find and we can go from there.
Nov 26, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Maytag 20 cu. ft. Upright Freezer MQU2056B Logo
101 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
Ismael Rodriguez...
Dennis Boxerman
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
