Question about D-Link DI-624M Router (DI624MRE)
D-Link DI-624M During update firmware v1.20 with v2.50 , original firmware has crashed. And Even trying several time by the reset in back , I cannot access router web interface anymore.  And what is strange is the IP adress that IPCONFIG detect is 169,134.xx.xx . So impossible to goto menu . Any repair suggestions or other ideas. Thanks
  • 1 more comment
  • chsajjad Apr 08, 2008
    NO. I did with wire co
    I tried to update the firmware version on my Dlink DI-624M router hardware from 1.2 to 2.5 and know my router is not working at all. Called customer support and they finally got it to where I can see the router by holding down the reset button for 10 seconds while the power is plugged in, taking power out and continuing to hold for 30 seconds, and then plugging power back in and holding reset button for another 10 seconds and finally releasing the reset button (reset button was held for a total of 50 seconds without releasing).
    After this I can ping 192.168.0.1 which is the routers address and a page showing Firmware upgrade is shown and not the usual GUI. It asks for file path to upload so I am trying to use the last working firmware which is 1.2 and 2.5 but when trying to send to the router I get the error "wrong image file” selected for both above files.
    It is a .bin file I have tried both of them and here is the link to where I have downloaded it from
    http://support.dlink.com/products/view.a...
    What do I do to put firmware on my router? Could you send right Image file so that I can run firmware to access my router.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    When you typed in the IP for your router interface page you said you got a different GUI. Was it a D-Link router GUI? Could you get into the router? If you could (password should be let blank since back at factory defaults) can check firmware version? I think it's under the tools tab and firmware. It should tell you the firmware version. If you can't get in, power down your router for like 60 sec, I like to be sure, then boot it, check the lights and see if you can get in. Also, could you please tell me what rev your router is? I think its on the bottom. It will have ser.#, model # that stuff. I need the router rev lwtter. Thanks.
  • Jeffrey Pemberton
    Did you try and upgrade the firmware through a wireless connection? Is the router working?
    Scholar:
  • 150 Answers
Looks like the file that gets downloaded has a .bix extension.
Try changing the extension to .bin
Then try the update
I think I had to do that when it first came out.
Posted on May 24, 2008
2 Suggested Answers
MysteryFCM
  • 187 Answers
SOURCE: D-link di-624m
169 is an internal IP. If you are not already, try a hard wired connection to the router. If this fails, you will need to get in touch with D-link.
Posted on May 25, 2008
Will this work on the imac new 21.5inch?
Yes, it works perfect. but next time but a better brand, d-link routers aren't reliable.
Regards.
Jul 26, 2010 | D-Link DI-624M Router (DI624MRE)
I bought a used D-Link wireless router DI-624M, it didn't come with the cd to download the program. I've reset it back to the default, but when I plug it in, nothing comes up. I've tried looking at the...
Well you need to log into the router and set it up.First of all if you are using dsl you will need to set it up for dsl.If its cable you need to set it up for cable.Go to the website and follow the set up instructions.
good luck
Nov 11, 2009 | D-Link DI-624M Router (DI624MRE)
DI-524 status problem
Did this happen after a firmware upgrade? If so, this link may help:
http://borgetech.blogspot.com/2007/09/d-link-di-524-revision-b4-status-light.html
Apparently there's a utility which will force firmware to load on the router. The steps are a bit technical, though.
If that doesn't work, the router is probably toast. Time for a new one.
Feb 08, 2009 | D-Link AirPlus DI-524 Wireless Router
I can't connect to wireless
looks like a firmware corruption. try running a firmware update from http://support.dlink.com/products/revision.asp
Oct 15, 2008 | D-Link DI-624M Router (DI624MRE)
Windows Vista to a Wireless DI-624 problems
I have a Toshiba Satellite connected to a Di-624m and I have the same problem.
One solution to many problems with D-Link is to ;
UNPLUG BOTH MODEM AND D-LINK.
WAIT 20 SECONDS (TWENTY SECONDS)
PLUG BACK IN AND TRY TO CONNECT.
DO NOT JUST SHUT THE POWER OFF, IT IS NOT THE SAME!
IF YOU DONT UNPLUG LONG ENOUGH IT WILL NOT WORK.
RECCOMENDATIONS:
CONNECT DIRECT WITH A LAN CABLE TO D-LINK
EVEN BETTER
CONNECT TO YOUR MODEM WITH A LAN OR USB-VERY FAST.
REPLACE THE D-LINK HUB! (LESS THAN A $100 !?!?!?)
WARNINGS-
OUR D-LINK ROUTER HAS CAUSED PROBLEMS FOR THE PAST YEAR ON OUR NETWORK, SOME OF THESE PROBLEMS WE BLAMED ON VISTA.
This wireless enviroment can corrupt downloads.
I went crazy trying to solve several download errors.
connecting direct to the hub with a lan cable solved the problem.
I have totally lost faith in this wireless system.
sorry D-link the di-264m is HISTORY soon.!
haydenshaw3
Apr 17, 2008 | D-Link Wireless
D-link di-624m
Apr 06, 2008 | D-Link DI-624M Router (DI624MRE)
Even with back reset hold for 10 sec. No reset at all
Check to make sure you're using the correct power adapter for the router. Your computer uses a 169.... address when it fails to connect to the router...this is a normal symptom when the router is not working correctly. Your router may have failed and will need to be replaced.
Jan 16, 2008 | D-Link DI-624M Router (DI624MRE)
DI-624M has "limited connecyion" perhaps due to damage to its firmware 10/20/07
          You need to upgrade the Dlink firmware,, that will do it.
Oct 21, 2007 | D-Link DI-624M Router (DI624MRE)
Forgot my password
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Forgot my password
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
D-Link DI-624M Router (DI624MRE) Logo
515 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
