Question about Hobart A200 Stand Mixer
? Hobart A200 Mincer/Mixer wont work
Hiya Mr Bigg T,
I have just been given what I think is an old Hobart A200. It has a mixer arm and has the ability to mince and slice too.
The only prob is that a mouse has got inside it and ate some of the wiring. I have tried to replace what I can but its still not working.
Please could you Oh Great one offer some help or tips. I would really love to see this old maichine working again because im sure it is worth a few pennies. Im see this as a project to get an old bit of mechanical history working again. It would also really help me out because at the moment I have to mince 20kg of chicken everyweek on a hand mincer.
So any help will be truely treasured and appreciated.
All the best,
Nik
  • Nik Seath
    Nik Seath Apr 12, 2008
    Thankyou for spending the time to respond.
    Unfortunatly the machine doesnt hummmmm at all. The dam thing does nothing. When I press the green switch in it doesnt engage, click or anything. I have changed the plug and fuse, yet nothing.
    I will try your tips and let you know how I fare.
    Wishing you all the best,
    Nik
  • 20 Answers
Does the motor have brushes? If so the mixer will have two removable covers on the back motor plate. If so take some light sandpaper to the part called the comutator that these carbon brushes ride on and make them shinny. If you have a newer style motor that doesnt have brushes. pull the motor cover and make sure the start switch is cleaned by sanding the contacts. If you check your wiring with a ohm/volt meter and it all checks good, well, the first question I should ask is does it hum? if not, the problems in the wiring or power switch. if it humes the problems in the comutator, start switch, capacitor or your motor is shot. unlikely for a mouse infestation. most likely wiring or switch problem.
Posted on Apr 11, 2008
SOURCE:
Hobart mixer A200 Rotation
Assuming the unit is 120v, single phase, my money is on a bad electronic start switch (not to be confused with the on/off switch) It's not visible without some disassembly. Usually, it is located at the rear of the motor cavity. Take note of all the info on your model data plate then go here to obtain a parts breakdown on your particular mixer. http://www.hobartservice.com/Parts/
I'd suggest replacing the capacitor as well.
Sep 28, 2009 | Hobart A200 Stand Mixer
Small screw and nut?
By turning the screw cw or ccw it adjusts the clearance on the worm shaft assembely,in other words if the mixer is noisy by adjusting this screw you can quiet it down.
Mar 30, 2009 | Hobart A200 Stand Mixer
Hobart A200 transmission issues
does not sound good it need to be torn down and checked from here thats more then can be figured out sorry
Nov 26, 2008 | Hobart A200 Stand Mixer
Hobart A200 Mixer not working
Sundance,
Please visit the corp website www.hobartcorp.com and click on the "Sign In" link in the upper right hand corner. You'll need to complete a brief registration form, but then you'll land in the Hobart Resource Center.
Hobart no longer manufactures the A200 mixer - but you can review and download a user manual and a parts catalog from the Resource Center on your mixer. That should help you understand the parts need.
We do sell replacement parts direct to end users, just visit our service website at www.hobartservice.com - and click on the "Locate on Office" link. You'll be able to contact your local Service branch to purchase a replacement part OR to have them take a look at the unit and provide a quote on fixing it.
If you have additional questions on Hobart products - please contact me at [email protected] .
Thanks!
SHerri
Oct 11, 2008 | Hobart A200 Stand Mixer
Gear problem
Sounds like a sheared key,explain your problem a little more i work for hobart.
Jul 26, 2008 | Hobart A200 Stand Mixer
Hobart A200
Hi I work on these all the time, sounds like a tooth from the one of the gears has sheerd off so making the gear rings rotate when they should sit solid in its casing..... you need to open her up or get a tech to look at it £150 is an approx fix
fritz
Hobart 20 quart mixer
Hey tom dont worry about it.These mixers hold a decent amount of grease.If you need any other info let me know.
Jul 23, 2008 | Hobart A200 Stand Mixer
Manual for Hobart Mixer A200
You can go to hobartcorp.com and register for free then you can print or download a parts
manual to help you to do repair. Hobart provide service manual to their technician only.
May 05, 2008 | Hobart A200 Stand Mixer
What kind of bang was it ? an electrical or mechanical. The A-200 has a stator and rotor assy with a start capacitor and relay behind the back cover at the head of the unit. You can access the retaining nut for the rotor (motor) shaft by removing the small 2 inch cover and getting a wrench on the nut and spinning it by hand. The handle you mentioned with the three numbered selections are your speed settings and everything is driven through a planetary drive. Hobart A-200 have been around longer than I have (im 48) and are work horses and in my opinion, are the top of the line for mixers. Put it this way, I would take a 25 year old A-200 over a brand new Varimixer or other brand name. You can access parts manuals and break downs on Hobarts web site with model # and M/L # any other question e-mail me [email protected] if you cant find what you are looking for I will e-mail you a wiring diagram (found behind the small gear selection cover on side) Good Luck......Rick
Apr 06, 2008 | Hobart A200 Stand Mixer
Hobart mixer
Please be more specific of what part you need.Whats the problem with the mixer?Im a hobart tech and service these mixers often.
Feb 18, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
219 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
