Question about Vacuums
There is no power, how do i open it up to get to the cord end inside, and then maybe the switch.
  • BobboBobbo Apr 06, 2008
    Same symptom as Bradmatya. No power. Tried multiple outlets, so confirmed it wasn't a problem at the source. Put a multitester across the leads of the power plug and got no reading with pwr switch on or off. Suspect the power cord is bad. Need to know if it's just the plug or on the other end.
    How do I open the motor area to access where the cord enters. I need to be able to check the inner ends to see if the cord is bad.
  • 29 Answers
To fishkeeper, I checked, it's kaput. So I gave up and went out and bought a Eureka Boss. MUCH better vacuum for a lot less money. I'm almost glad the Vax had a heart attack.
Posted on Apr 19, 2008
Hi common fult with this one its usualy the power switch, pull off wheels (strainth required) unscrew the 4 torx screws and the two on top, pull apart housing you will see red button where power swich is, connected with two wires, its a in out switch if it does not stay in its kaput, ebay is the only place i found the switch.
tally hoooo
SOURCE:
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
Got a Filter Queen Majestic Limited Edition, the one with the high and low power switch, an I have to change the power cord. How can I open the main unit to reach that power cord? Thanks,
first remove the top cap under your handle.
Then, remove the three screws under the handle.
remove the rubber cover on the switch
undo the clamps on the side of the unit
lift off the chrome cover with the cord on it by the handle itself.
When you have the access there, change the filter inside the upper chamber as well.
Good luck
Nov 15, 2010 | Filter Queen Majestic Canister Vacuum
My vacuum won't turn on
Check if light is coming on, if it is there maybe something caught under the switch. what I think it will be, you have streched the cord braking it inside, fix or replace cord.
May 08, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No power from Kirby!!
Determine if the headlight works before anything else. If the light works but the motor won't you have power thru the vac and the problem is internal possibly motor brushes... or a loose wire on the inside connecting to the switch.
If the light goes out is likely a switch or cord problem. Switches on these vacs break more often than cords. What you see on top is the switch button, not the actually internal switch, however a switch does not normally fail while the vac is running, that sounds more like a loose connection or a bad cord.
So isolate the cord. Unplug it at both ends and plug lamp ( or test meter) into the cord into the cord and gently wiggle where the plug end meets the cord. If the lamp goes on and off the issue is the cord. You can buy a replacement specific to the Kirby series and plug it in yourself. If this s does not isolate the problem, take it to a service center. Kirby is very intricate inside.
Sep 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have a Hayden SuperVac 3600, almost 10 years old. The unit still runs, but now when I switch to the power nozzle, it doesn't have power to turn that. I think this happened once before and maybe they...
The hose has fuseable link inside, generally a 3-7 amp. It is at the wall end underneath the hose cuff. Easy to replace as it crimps in line. If you have a meter you can also test the detachable hose to wall cord for continuity, then check the hose to handle as well.
You can also detach the hose to wall cord from the hose, and plug your power head directly into that cord,, then into the wall thereby eliminating the hose itself.
Hayden makes a serviceable hose. If damaged or the fuse blown it can be serviced by a good tech. If the fuse is blown you need to clean and inspect the power head as this may be the cause
Jun 20, 2009 | Hayden Industries SuperVac 6000 Central...
Acin and sparkin
HI
Im guessing its a break in the cord where it goes in by the switch
Feb 18, 2009 | Fantom Vacums FM740 Twister 300SE Bagless...
Replacing Power Cord Kenmore Progressive Upright
That actually sounds correct, if it's the model I'm thinking of. As long as you're talking about connecting to the wires that are held in by the wire nuts you should be good to go.
-R
Oct 25, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
My hoover keeps cutting off and on, now it doesn't even come on. I have checked the fuse its ok and i can't cheak the wireing,the plug is moulded into the socket.
Chances are your cord was damaged inside the insulation and over time it finally opened. That would cause the cac to not operate any more. If you have access to or one of your friends has a multimeter then you can check the wiring by using that meter in the OHM mode... and placing one lead on each of the two plug terminals at the end of your cord ( not plugged into power of course ) and put the vac switch on.. you should not see an open circuit and read something in the range of 10's of ohms to 100's of ohms ...depending on what path it takes.. ( meaning that with the switch on.. you should be measuring resistance through the motor windings and/or light bulb ..if it has one... That would be a quick test of your wiring integrity... Hope that helps..
Aug 21, 2008 | Hoover Vacuums
Bissell 6900 stopped working how do I open the thing?
Bissell 6900 Digipro ON OFF Power Switch failed. I found the wire connectors for the power switch were corroded. I fixed this by soldering the wires directly to the terminals leading to the motor. To access the circuit board and the on.off power switch I pryed off the cover for the on /off power switch and the cover for the cord retraction leaver. The covers are held on by two tabs that extend under the red cover on the top of the vacuum. Push the switch cover away from the red cover while prying the cover upwards, You may damage the two tabs on the switch cover, as I did, but afterwards, the cover went back in place and appears to work okay. WARNING: This is a home made repair of a 120 VAC circuit. If you are un qualifued to do this repair you face serious risk of a faulty solder and fire inside the vaccuum cleaner. 4fd9446.jpg78baa14.jpg
Jan 26, 2008 | Bissell 6900 DigiPro Bagged Canister...
How do you take the DC11 apart?
Unplug the unit from any power first.
To get the unit apart you have to Carefully pry off the wheels from both sides of the unit to allow access to another 4 torx screws. Use a longer flat blade screw driver and insert this between the wheel and the body of the vacum as close to the wheels center of rotation as much as possible. This should allow you open the clamshell like case. Once inside you can test the power switch and connections. My switch tested good but there is a problem with the power cord that I am trying to determine.
I am trying to replace the cord but the cord reel assembly and cord seems tighly integrated so I may end up buying the replacement power cord assembly if it is available for purchase to the general public and not only service centers. I will try the plug into the wall assembly first as it is easier to replace.
Good luck
Jan 03, 2008 | Dyson DC11 All Floors Bagless Canister...
Vacuums Logo
105 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
