start simple, make sure water supply is ok. if this ok i would be lookin at the inlet valve, its solinoid could be faulty. located inside dishwasher where water hose screws on.
also on dishwashers a broken wire inside the door skin where wires loop into bottom would be fairly common.
This is most likely caused by build up on the filters inside the dishwasher. The best thing to do is to run it thru a cycle with vinegar. To do this, empty the dishwasher, start it on a normal cycle and listen for it to start filling. When it starts to fill, open it and pour about 1/2 to 3/4 of a gallon of regular white vinegar in the bottom of the dishwasher and close the door. Let it run thru the rest of the cycle. That should help. Run this as maintenance about every 3 or 4 months. Hope this helps!
dishwasher leaking from the door or from the bottom of the door is common problem and yes its advisable to get it fixed.but if its having any other problem other then leaking then it has to be checked first.but leaking problem is common it can be solved.first from which part of the door area the leak is occuring that has to be checked. Some common leaking trouble makers.... Leaks at the door: Door gasket loose/torn Corner gaskets or door baffle/vent gasket Door lock/latch loose/broken Split spray arm Over filling with water...usually the level is just under the heating element is normal Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button. Door hinge(s) bent Wrong soap was used...dish sink soap instead of dishwasher soap Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit: Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help Hose for upper spray arm split Fill hose split or fill hose spout air inlet is calcium covered Drain hose is split Rusted liner...metal liners only Fill valve leaking or allowing water to fill all the time Heating element ends....where they come out through the dishwasher liner Float or float gasket
for parts you can get it from www.repairclinic.com
How about if you fill it up manually? As in fill up a pitcher, pour contents into the bottom of the dishwasher until it raises the float. Close the door and see if it runs. (don't put so much in there that it pours out the open door)
If it runs and you are sure the water is on. Turn the water off. Take the inlet line off the dishwasher's electric control valve and see if the inlet screen is covered with trash. If it is, clean it off, put it back togehter and see if it works.
Unfortunately there is no easy way to completely get the detergent out of the rinse aid reservoir in one quick method, short of taking the inside panel off the door.
However, I would try a simple way to flush it out. With the door open almost al the way open, pour warm/hot water into the rinse aid fill hole and keep pouring until you start to get clear water coming out. The water will be flowing back out the fill hole you're pouring the water into and should just flow down the door panel into the dishwasher tub. Try to keep the door about 10-15 degrees up from all the way open to let the water get in the rinse aid reservoir.
Just pour the water in slowing so you don't agitate the mixture and you should be able to get it running clear in 5-10 minutes. It could take a gallon or so of warm/hot water to accomplish this, but it will flush it.
When you'r done, just put the dishwasher into a rinse cycle to pump out the water and soap, etc. You may have to run a full cycle afterwards to get rid of any excess detergent in the tub.
Step1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely. Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary. Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet. Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement. Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
