Question about Eureka Enviro Steamer 310 Stick Vacuum
Need directions on how to clean clogged steam nozzle
If your steam mop is Enviro Steam Mop by Eureka. remove the 2 screws on the bottom of the steamer, that holds the center panel on. (Not the screws that hold the whole bottom.) Use a needle the clear the steam holes. Soak the panel in white vinegar for a couple of hours and scrub with aa brush to remove the lime calcium deposits. Check the center hole that goes into the steam and make sure it is clear. Reattach the panel. If the panel does not fit snuggly (either end does not contact the base panel, add two more screws about an inch in from either side. I used stainless steal screws because of the consist moisture. Used screws that are no more than 3/4 on an inch long and about the same diameter as the two you removed.
Posted on Oct 26, 2008
3 Suggested Answers
SOURCE: No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Posted on Nov 08, 2007
heatman101
  • 43501 Answers
SOURCE: I have Shark steam mop. When I used it and
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Posted on Sep 04, 2010
Oreck steam cleaner, it doesn't give out steam
Use the tool that came with it to clean the nozzle where steam comes out. End nozzle also comes off so you can clean the larger hole with the other scrublike side of the tool.
Also, listen for steam assembly working, a low rumble like sound. If you do not hear it, it is broken and needs to be replaced.
Oct 07, 2016 | Oreck Vacuums
Water heats up but no steam comes out
Make sure the nozzle where the steam comes out is not clogged. Minerals in tap water may clog it cause it's very small opening.
Sep 03, 2013 | Oreck Sanapathic DMS2000 Handheld Steam...
Is there a trigger handle to turn off and on
no betty, stupid bit of kit imo, no operating switch, just on/off at the switch, which heats the water up. i measured 500ml of water heated using my kettle, put the top on, switched on, and waited. first time the steam didn't come out of the nozzle, so i removed the end and cleaned the nozzle with water, blew down the end from the big end, and replaced it, steam came out. big grumble though, the steam coming out is not that warm, don't advise you to, but i directed against my fingers, it's only hot at the exit of the pointing bit, used it to try and clean floor tiles and grout, complete waste of time. i wouldn't advise anyone to buy one.
Dec 11, 2011 | Tristar SB Steam Buggy Vacuum
How to remove hood from hoover steam cleaner deluxe I can not find how to remove hood its on top of nose of steam cleaner
Hi Lisa,
Do you need to clean the nozzle or do you need to do repairs inside? You only remove the hood to do repairs. For cleaning the nozzle, refer to your owner's manual as to what to do after you finish cleaning. There is a description for how to clean the nozzle.
If you need to do repair, please reply back. Thanks,
Handie Andie
Apr 24, 2011 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
My brand new h2o mop won't steam. Green light comes on and thats it.
bought it a few years ago - I used it a few times and it was fair but did leae a lot of water on the floors. My wife had wanted it as it was supposed to be a miracle device, but she had some health issues and not able to do heavy housework. She is better now and decided to try this miracle device she had wanted so bad - so we took it out and no steam - so this would be it's 3rd use and it's was dead. I'm a bit of a tinkerer so decided to take the thing apart/clean the nozzles etc per the troubleshooting guide. Well, none of the obvious/accessable nozzles were clogged, and the filter seemed to pass air and water ok (probably does have to be changed due to time vs uses. Anyway, took the unit apart and ended up having to take the pump motor apart - there is a little nozzle/connecter on the back of the motor that passes the water into the heating chamber. cleaned that with a pin - put it back together, and tons of steam shooting half way across the room. So - she did the floors, they are wet but clean. Bottom line - does an ok job but leaves a lot of water behind, and it appears the internal nozzles can be a problem, and not something the average householder would want or be capable of fixing. (they do say you can try using WD-40 in the unit to clear nozzles - not sure how it would get through to the pump nozzle, but maybe this would work ??
Anyway - may end up buying some more filters as we will want to get a few more uses out of this thing for our $100 bucks, but will stay away from them in the future (go back to the wet swiffer - does about the same job but much less cost and hassle).
Mar 07, 2011 | H2o TR220002 Steam Cleaner
I have Shark steam mop. When I used it and everytime I pump it and the steam will not come out. so, I think that it might have the clogged the nozzle. How can I clean it up?
heatman101
Mar 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
Steam vac
Either the nozzles are clogged, or the brush block is not turning.
Mar 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
No steam release
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Eureka Enviro Steamer 310 Stick Vacuum Logo
622 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
