Question about HP Compaq Presario V2000 Notebook
Need Help Using the Presario V2000 Expansion 2 Port
I have a Compaq Presario V2000 Notebook. I wanted to connect the laptop to my television. I thought it would be easy enough, but nothing is ever easy 4 me. I can't get an s-video cord because my TV is too old. After looking around the net I came to the conclusion I would need an s-video adapter. One Radio Shack, P.C Richards, Micro Center, Best Buy, and Wal-Mart later, and no luck. For some reason I can't find an S-Video adapter with plugs that match up to the holes on my S-Video port. So I checked the manual for the notebook and it says the only way to connect my laptop to and "old" TV (red, white, yellow plugs for sound and video) is to get the HP XC2000 All In One Media Cable. I was ecstatic until I went to try to order it and there was a little asterisk next to my model number. Long story longer, the cable will only work if I have the Expansion 2 productivity port. How do I know if I have it??? (I called HP, but I ended up on the phone for about 2 hours with 3 different people who were very, very nice, but weren't much help).There is a thing that looks like a little door on the left hand side of the laptop (which in the manual is labeled the Expansion port), but I see no clear way to open it, and I don't want to pry it open ad break the laptop. Any help would be great :) Thanks...
  • Anonymous Dec 21, 2008
    I have the same problem of connecting my Presario V2000 to my Panasonic 29" television and Phillips 32" Ambilight LCD. I used the VGA cable which has two output ( video -the yellow pin & S-Video) attached to it. It's suppose to be as easy as Plug N Play operation but the picture just doesn't show up on the tube. Thanks for enlighten me....
  • 4 Answers
If you have a little plastic cover where the Expansion Port 2 should be, then your specific model doesnt have the port. i know what you mean, when I got my first V2000 i thought the same thing, that there is a port hiding there. my second V2000 had the expansion port instead of the cover. so did my V5000.
If you have an S-Video jack on your V2000 (i guess you do?) then you can make an S-Video > Composite (yellow video jack) adapter. it involves cutting open both an S-Video cable and a composite cable and wiring the ends together. Both the red and white wires inside of the S-Video cable get connected to the center pin/wire of the composite cable, and shield/ground wires get hooked to eachother. your laptop should detect the TV as an S-Video connection even though the laptop is now putting out a composite signal. there btw is no danger of shorting out the laptop or the TV, because we are dealing with analog signal wires with little actual electrical current. you may get weird lines and/or a black and white picture if not done correctly. so just double check your connections, and reboot the laptop with the TV connected and on a few times, and it should be working in full color.
one more thing, if you do not want to go splicing cables, you should be able to use an S-Video > composite adapter that came with an Nvidia/ATI desktop graphics card. its the same thing.
Posted on Aug 20, 2008
  • 520 Answers
You can get s-video to scart connections;and if youve no scart you can connect s-video to phono....thats ur red,yellow n white audio / video plugs.yellow=video...white/red=left/right audio.
if you download a service manual it shows the pinout for s-video connections making it able to connect phono' only need the yellow and either red or white cos pc only outputs mono to tv.
there are also wireless systems you can get though never tried them.
you could also connect to another monitor,just plug the monitor into the back of pc(ext)only go into on place one way so no prob there.if no picture on ext monitor u need to switch screens
(alt+f 4) together once switches to ext mon,press together again enables both screens,and again returns to pc.
Posted on Apr 07, 2008
I need a sound driver for my sound and video...
This isn't as simple as we were thinking, actually it's easier for us to assume or to give you the specific solution and link if askers mention the Operating System installed on their system. Since you didn't mention, I have to assume myself, I can't give you the direct link, but I will only give you the link where you can download the drivers with instructions on how to do.
More than that, there are three Compaq Presario v2000 Pc notebook models, well from the links below, select what is best for your system.
1. Compaq Presario V2000 Cto Notebook Drivers.
2. Compaq Presario V2000 T Cto Notebook Drivers
3. Compaq Presario V2000 Z Cto Notebook Drivers
Open the link, select the operating system installed on the system and click "Driver-Audio" to download Sound Drivers and "Driver-Graphics" to download Video Drivers.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Jul 10, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 PC Notebook: All ports are "in use" with nothing connected. I c...
Click on start. Then click on Run.
Type in MS config.
Uncheck load startup Items.
click on ok and then click on restart.
Any application which turns on and starts using your port when the computer turns on would stop loading on their own and you will have free ports to use.
May 17, 2010 | HP Compaq Presario V2000 Notebook
I lost my compaq presario v2000 laptop audio driver hw can i get it back
you can download your compaq presario v2000 audio driver from here
Click to Download
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Mar 24, 2010 | HP Compaq Presario V2000 Notebook
Do i have a serial port on my v2000
The v2000 does not have a serial port. You would have to get a USB-Serial adapter to make that sort of connection.
Jul 02, 2009 | HP Compaq Presario V2000 Notebook
Give free driver of presario v2000 laptop
Compaq Presario V2000T: download here.
Compaq Presario V2000Z: download here.
Jan 16, 2009 | HP Compaq Presario V2000 Notebook
Help me please>>>My Notebook Compaq Presario v2000 haven't sound.
To install device you need to install device driver within cd support included of the pack, or goto then click the support for download driver for your device.
hope this help..
Nov 07, 2008 | HP Compaq Presario V2000 Notebook
Drivers for HP Compaq Presario V2000 laptop
link to v2000 CTO
link to V2000 support page, you select which series, click on it then select which operating system you are using.
Apr 07, 2008 | HP Compaq Presario V2000 Notebook
Problem of video controller(VGA Compatible)
Out of the three, which one is your model.. Compaq Presario V2000 CTO Notebook PC Compaq Presario V2000T CTO Notebook PC Compaq Presario V2000Z CTO Notebook PC Please specify and also about the OS you are using?
Sep 16, 2007 | HP Compaq Presario V2000 Notebook
Ethernet not working! Help!
im assuming its not dissabled, if not then go to control panel, network connections and right click on your network card and go to properties then driver and see if there is a code 9 meaning it's faulty or the device is working. if it is faulty then it's part of the motherboard anyway and you will have to buy a pcmcia network card and connect through that instead
Sep 04, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
1,207 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
