Question about E-Machines eMachines Desktop PC
AOL Idle Timer
AOL boots me off during microsoft updates...how do I turn off the timer?
    Problem Solver:
  • 11 Answers
Check settings
Posted on Apr 13, 2008
Timer turns off during cycle
Yes. The timer needs replaced. Either the motor inside is getting too weak to turn, or the gears are stripping out on it.
Apr 30, 2012 | Washing Machines
Without doing the minimal setting test to see if a time clock works how do you test a time clock with defrost termination the x terminal
8145-20 is 240Volt defrost timer:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8045
You are testing the 8145-20 timer.
The timer dial should rotate continuously. Trippers on dial rotate around. When they reach the trip switch, the timer starts the defrost cycle.
Terminal 3 has power during defrost cycle.
Terminal 4 has no power during defrost cycle.
With 240Volt timer, terminals 1 and 2 and N and X test for live power to ground at all times.
The limit switch is connected to terminal X and to terminal N.
During the defrost cycle, the limit switch measures the pressure or temperature.
When pressure or temperature reaches the set point, the limit switch closes the circuit and this trips the solenoid inside timer. The solenoid turns off the timer relay, and the defrost cycle ends.
At this point the timer turns off the defrost, and sends power to the refrigeration.
Terminal 3 has no power during refrigeration cycle. (The opposite of defrost cycle).
Terminal 4 has power during refrigeration cycle.
Test these terminals for power to ground. One or the other should have power at all times, but not both.
If timer will not enter defrost cycle, make sure the X-3596 trippers are not worn down.
Disconnect the wire to terminal X and see if defrost cycle will start.
Test terminals 3 and 4 again and see if removing wire from X caused a change.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Paragon 8145-20 Defrost Timer
How do I set timer
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Rotate selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
Dec 14, 2010 | Intermatic Outdoor Timer/Photo Control...
I have a paragon 8145-20 defrost timer. do you wire the compressor to the timer? I cant seem to find a wiring diagram on how to wire this correctly
Link below has wiring diagrams and wiring manuals for 240V 8145-20
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
I am not expert installing defrost timers.
According to information from Paragon, 8145 is for hot gas defrosting. 8140 series are time initiated, and pressure-or-temperature terminated.
Wiring diagram does not show compressor wired to timer.
The cycle works like this:
Timer is running but defrost is not switched ON.
Fan is ON.
Timer switches ON and activates defrost cycle.
Fan turns OFF. Hot gas valve turns ON for defrosting.
Cycle limit switch is temperature or pressure sensitive.
Cycle limit switch reaches trip point, timer switches OFF.
Hot gas valve turns OFF. Fan turns ON.
So fan is off during defrost cycle.
Hot gas valve turns ON when timer switches ON.
Timer is switched OFF by pressure-or-temperature limit switch.
Dec 09, 2010 | Paragon 8145-20 Defrost Timer
Please e mail the intermatic timer instruction model# 59419 rosecthimote@aol.com
59419 is the Woods 2 pack plug in 24-hour dial timer with 2-prong outlet.
If this is not your timer, add a comment.
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
See all Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Manual for Woods 59419:
http://waterheatertimer.org/pdf/Woods-59419.pdf
Instructions:
Rotate dial until current time lines up with arrowhead located on inner dial
When plugged in, dial rotates
24 segments located around outer edge of dial; each segment is 1 hour
You have to pull these segments up using fingernail or small screwdriver
Segment pulled up = lights OFF
Segment down = lights ON
Override switch located top of timer, move switch to TIMER
Plug lamp into timer
Make sure lamp is turned ON
Plug timer into wall
Dec 04, 2010 | Woods Hardware & Accessories
How to remove dual booting?
the easiest way to remove dual boot is to disable the timer for Operating systems displayed during start-up, so that you do not need to wait for 20 seconds or select the OS you want.
simply right-click on MY COMPUTER, go to PROPERTIES and then choose ADVANCED tab. you will see option for DEFAULT OPERATING SYSTEM and then uncheck TIME TO DISPLAY LIST OF OPERATING SYSTEMS. Or you can just set time to 0.
Good Luck.
Oct 18, 2010 | Microsoft Windows XP Professional
Setting
manual for HB51RC
See timer at Amazon
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
I want to program my 360 to shut off at a certain
If your wondering if there is a timer built inside you can set unfortunately there is not. You could use a timer for the plug to only turn on during certain hours of the day like they use for Christmas lights.
Hope this helps.
Sincerely,
Michael Scott
Jul 15, 2009 | Microsoft Xbox 360 Console
IDLE TIMER FOR 2008 F550
refer thge owner's manual of 450, u'll get these kinda details there.
Feb 27, 2009 | 2008 Ford F 450 Super Duty
E-Machines eMachines Desktop PC Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
