Question about Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot C330
It worked great yesterday.
Today it will turn on and inmediayely turn off.
Change cars ...change source of 12V....nothing.
Please help.
  • nimbler Apr 17, 2008
    i turn on and i see street pilot and after it turn off it s impossible to see more
  • Anonymous Apr 18, 2008
    Stopped working.....pressed reset and it came on for a few seconds and back off again.
    Was using Aotu plug in power...No prior problems.
    Bought unit 15 Dec 07
Question: Why won't my StreetPilot c3xx power on?
--> Answer: If your StreetPilot does not power on, or if it turns on then turns off, you can troubleshoot the problem by resetting or charging the unit. The reset is a "soft" reset that you can perform in the car; it restores power to the unit, but it does not remove data.
To reset the unit:
  1. Place the unit in the cradle and roll it backwards slightly to lock it in place.
  2. With the key in the car ignition, turn on the unit or put it in accessory mode.
  3. On the face plate of the unit, put your thumb nail in the groove under the Garmin logo and gently pull off the face plate.
  4. With the face plate removed, press the reset button on the right side.
  5. Turn the unit back on. If the unit still doesn't power on, you may need to charge it.
To charge the unit:
  1. Using the provided USB cable, connect the device to the computer.
  2. Reset the unit (following instructions above).
  3. Keep the device connected to the computer and allow it to charge overnight (7-8 hours).
  4. After charging, unplug the unit and power it on.
Posted on Apr 17, 2008
  • 174 Answers
Check the fuse at the tip of the power cord. Unscrew the round black plastic and this will release the fuse. Otherwise there could be a problem with the power cord. If the cord is defective, replace only a Garmin replacement.
Posted on Apr 15, 2008
2 Suggested Answers
  • 2275 Answers
SOURCE: Garmin Street Pilot C330
Verify that you are getting 12 volts from where you're connecteing this device.
Posted on May 14, 2008
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
May 14, 2008 | Garmin StreetPilot C330 GPS Receiver
How do I change the batter in a Garmin Street
Hi! You may need to change the fuse periodically, which is at the tip of the adopter! regarding battery, you may need to contact waste disposal section for disposing the unit since it contains lithium. Don't consider much presence of high amount heat and direct sun rays at new battery for longer duration and have fine
Dec 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Need battery for street pilot c330
THis battery will work in your C330 Garmin. I have had it in my unit for 3 years now without any issues.
http://www.etronicspal.com/132805.html
Just open the unit and splice the wires, and use some electrical tape. Good as new.
Jul 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot c330
Pull the face off try to reset it, if it will not reset, or work in the car or the house, the battery needs swapping out,
Garmin $100
Regards
Jun 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c330 goes on and then goes off
Try to charge the unit for 4 hrs by using a wall adapter and then try power on it again and if still the same after you full charge the unit try to contact the manufacturer check if there is a latest firmware update for the unit.
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
How do I change the battery in a Garmin Street Pilot C330
Sep 06, 2008 | Garmin StreetPilot C330 GPS Receiver
Update 2009 for Street Pilot c330
2009 upgrade data is too large for garmin 330 must have sd card
Jun 08, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c330 instruction manuel
The instruction manual is available to download from Garmin's website, www.garmin.com. Click on the StreetPilot C330, then go to updates and downloads. You should find the manual there.
Mar 05, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
137 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
