Optimus system 1030
My Time Warner universal remote has codes for my DVD player, my VCR, my TV and of course the cable box. I cannot find a code that will work with the AUX button for my Optimus system 1030 and the original remote for that system stopped working long ago.
After much trial and error i found a code that partially works.... 3025
it controls volume, power, mute and the c button on the remote controls the genre of music. AND THATS ALL. no analog of songs no fwd or rwd, its better than nothing though.
Posted on Feb 02, 2009
SOURCE:
I need the codes to program a magnavox tv with built in dvd player with this remote
Your universal remote should have a code search feature that allows you to search through its library to find a code or codes that will work. You might need two separate codes for the TV and the DVD player.
Jun 19, 2015 | Audiovox RCR314WR Universal Remote Control...
Tip
One For All URC-1030 Reassign Key
One For All URC-1030 Universal Remote Reassign Device Key
Would you like to re-assign one of the function buttons on your One for All URC-1030 Universal Remote to control a different device?
If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
I hope that helps.
_______________________________________
One For All URC-1030 Manual
One For All URC-1030 Code List
One For All URC-1030 Code Entry
One For All URC-1030 Code Search
on May 30, 2010 | Televison & Video
Tip
I hope that helps.
on May 30, 2010 | One For All URC-1030 Remote Control
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
Feb 12, 2011 | One For All URC-4021 Remote Control
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Apr 19, 2010 | Televison & Video
How do i program this remote to my time warner cable box
Time Warner is most likely made by another company and they are not listed on the programming documentation. You can try looking online to see who makes your Time Warner box. You should be able to program the manufacture off of the program list. The universal code for this remote is 8107 and 8108 which may work as well. To program the remote press set and the light next to set will start flashing. Press the desired component button ex(TV , VCR, CBL, DVD). Next enter the code 8107 and press ENTER. The set light should no longer be flashing. If 8107 does not work try 8108 using the above info.
Feb 06, 2010 | Sony RMV210 Remote Control
Need codes for olevia tv
Olevia TV Remote Control Codes #tbltrouble TD { BORDER-BOTTOM: #cccccc 1px dotted; PADDING-LEFT: 2px }
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for all 2 Series, 3 Series, 4 Series, 5 Series, and 7 Series Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available, please call at 866-965-3842
Satellite TV Systems Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Cable TV Systems Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610
Jun 21, 2009 | Olevia LT27HVX 27 in. LCD Television
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
RCR451
Orion TV; 1030, 1035, 1191.
Emerson VCR/DVD; 2142/3391, 2148/3403.
Dec 16, 2008 | RCA Universal Remote Control
326 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
