Question about Maytag SAV2555A Top Load Washer
Maytag washer sav2555
Hi I took the washer apart i layed the washer down and i am spinning the belt by hand it will spin one way the other way it will spin for a second then it makes a click and it becomes hard to spin then it clicks the helix lug nut turns then it cliks like it is striped. could it be the spin pully or the other end of it the plastic helix drive lug? I was able to take the bolt of at the bottom of the and remove the helix drive lug but could not get the spin wheel of , because of the bottom of the washer there is no room to take it of,I was going to replace these parts.do you thing it could be the belt the belt seems oky to me , thanks again for your help
  • JagsRule May 08, 2008
    I have the same problem with my washing machine; same model. The helix broke in half and rounded off the edges of the pulley. I bought a new pulley and helix and would like to know the specific order of dissassembly to replace the pulley. I do not have an IPB for my machine.
    President:
  • Maytag Master
  • 2,651 Answers
The pulley will not remove very easily , it wold require removine the milk stool, motor and some other parts, not the easiest hing to do especially if not needed, the helix you removed, take a look at it , the sloped ends of it should create a pretty sharp angle, then a 90degree drop off, the slopes om the pulley should be the same, they should not apppear to be rounded off,helix is probly 10 bucks if needed and if its at the helix that you see the "slipping" and "clicking noise, before condeming the tranny i would start with tthe helix, if after re-installing it it still clicks up and over pully perhaps try adding another spacer under the bolt before tightening. the idea behind the pulley and helix is that depending on rotation of the transissiion, the helix "pushes against" the pulley adn spreads the brake plate, releasing the brake allowing the tub tospin freely
Posted on Apr 07, 2008
  • Pieter Badenhorst Jan 28, 2012
    Thanks for the great idea! I added a large washer under the helix of my Amana machine, and now it spins!
BELT BURNT FRAYED THEN BROKE, SOUNDED LIKE BEARING NOISE
It may be a garment stuck in between the inner drum and the outer shell
Aug 31, 2012 | GE WBVH6240F Front Load Washer
Maytag Neptune MAH4000AWQ
If the appliance does not complete the cycle, then it is probably a fault on the control timer, the part should be replaced.
Oct 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
WON'T PUMP DOWN OR GO INTO RINSE AND SPIN CYCLE
what about your lid switch?...have you checked it already?
tnx 4 using fixya,
drcool
Sep 27, 2008 | Maytag Neptune FAV6800A Top Load Washer
My Maytag Atlantis washer's motor run but it doesn't spin. The belt looks fine. What are other potential problems?
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced
best of luck
sonic boom electronics australia
please remember to rank this advice if it helps
Dec 22, 2010 | Maytag Atlantis MAV6000 Top Load Washer
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Pulley Came off!!!
pull the belt enough to spin pulley.use extension for you tools
May 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag SAV2555 will not spin
it does( withiut looking at it myself), sound like the pulley/helix are just slipping past eachother and not engaging one anoher, does the sloped side of the pulley(wehre it meshes with the helix appear to be rounded over???) thats really the only reason i could see to replace the pulley.. for get trying oto spin the belt can you grab hold of the p[uley and try spinning it directly????. rfeason i askl is that in order to replace the pulley, youll need to rease th springs around the bottom of tub, and remove the entire unit from the cabinet, after removing unit, turn unit upside down, you need to remove the motor,, then unbolt the 3 white legs form the outer tub, and remove the 3 brake pads bolted to underneath uint with 3/8 nuts, the stansion then will lifht up giving you room to remove the pulley. awful alot of work if not needed,
Apr 15, 2008 | Maytag SAV2555A Top Load Washer
Wont spin and makes a noise
def needs a pully to add tension in order to spin. reconnect adn watch what it does. where does noise appear to come from??? sometimes the lower most "helix" strips out on machine and sounds as if theres amototr boat in you machine.Its the bottom most item on the centraal shaft of the transmission held o by a 1/2 bolt. if either that or the pulley above it strip it wont dissengage the brake assy and will "motor boat" with no action from transmission
Apr 02, 2008 | Maytag SAV2555A Top Load Washer
Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Sep 27, 2007 | Washing Machines
Maytag SAV2555A Top Load Washer Logo
304 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
