Question about Maytag MZD2766GES Side by Side Refrigerator
Reply to your advise
Yalmer,
Thanks for chiming in. The freezer side is working well which leads me to believe the refrigerant is okay. I've been researching a bunch of sites, a few of the problems appear to be defroster related or damper related.
  • 552 Answers
If you have buildup of frost in one compartment, you may have a problem with the defrost heater. These heaters are there in modernfrg/freezer to keep it from building up too much frost/ice.
They sometimes need to be defrosted and then restarted to solve this problem.
If that does not solve the problem then you should check the defrost heater circuit to see if it is functional.
Posted on Apr 08, 2008
SOURCE:
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Led light not working in refrigerator
I have the exact same problem. I saw that I can buy a new LED light fixture for about $115 online. I removed my LED fixture and got no DC voltage difference on the wires when the doors were open or closed. This leads me to believe that the main circuit board is the problem. I also saw the main circuit board for about $125. I'd hate to buy the board and it not be the problem. Have you solved this yet?
Nov 15, 2011 | GE Profile PGSS5PJXSS Stainless Steel...
Ice maker is barely producing ice. Very little water is coming into the maker leading me to believe it's a line problem. The fridge is 13 years old. Please advise. Thanks,
Have you replaced the filter in a while? It can cause increased resistance to flow. How about your water, does it flow like it used to?
Jun 10, 2011 | Kenmore Top Freezer Refrigerator
Samsung model rs267 says OF on both temp displays
Freezer and refrigeration isn't working
There is no temperature indicating for Celsius of Fahrenheit it just displays OF.
The letters "OF" on the display of your refrigerator indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and the display returns to normal, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air. Thanks-Helpful?
Feb 07, 2011 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Freezer part is okay but refriger part not cold enough
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | Refrigerators
The freezer side not freezing just cool, the
Open freezer door, pull food off shelves on lower half of inside freezer and look if you have frost building up on the back wall of freezer. If you do then you have a defrost heater or thermostat possible gone bad.
Advise if you have frost build up and I will advise on how to check it.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Hotpoint fridge problem, warm fride, but freezer working good
Fridge along bottom shelves is much colder than the very top shelf which has milk etc., leading to spoilage. Fridge is at highest setting. In the upper left rear of the fridge compartment, is a cover for what I believe to be a circulatory fan. However, trying to remove this cover is difficult.
It seems that the clip nuts to which the two (2) small capscrews fasten are free wheeling and not allowing me easy access to the motor.
Please advise.
My model no. is HSS221FMD WW
Jul 20, 2009 | Hotpoint HSS25GFP Side by Side...
GC2224gek admiral freezer keeps defrosting and the food thaws. The fridge is working. Switch it off for a day and fridge, freezer and ice maker works. After a few days it starts defrosting and I noticed it...
I believe your defrost control board is defective part number 0165748 You can visit my site below and enter the part number or the model number GC2224GEK in the search feature. We also offer free help, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Kenmore model Number 106.53632300
WHEN YOU TURNON, CAN YOU HEAR THE MOTOR RUNNING NOISE,
DID THE FAN WORK? PROBABLY YOU NEED FREON
Jul 10, 2008 | Kenmore 53642 / 53644 Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
44 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
