Question about HP OfficeJet 6110 All-In-One InkJet Printer
FAX CONFIRMATION HOW DO I SET MY HP6110 TO PRINT A FAX RECEIPT FOR EACH FAX SENT.
    Scholar:
  • 53 Answers
perform the steps below:
1. Press Menu button on the front panel of the All-in-One.
2. Press 3 to enter in to Print Report.
3. Press 6 to enter in to Automatic Reports Setup and select Send Only from the drop down list
Posted on Oct 04, 2009
  • 27 Answers
-press menu
-press 3, then press 6 to select Print Report
Posted on Mar 05, 2009
Dell 1815dn Fax confirmation?
U CAN DO A FLEA POWER . \
1. restart the system ,
2. turn off the power / scan/ fax ,
3. unplug all the cable to the system and wall socket and then wait for 20-30 seconds .,
4. connect all the cables and give a try it should work.
Oct 20, 2014 | Dell Printers:Dell MFP Laser Printer...
Fax confirmation
most printer in the market has the same standard setting for the fax.
u can set the report many types for many user's purposes, some people want to save paper, save ink/toner, so they dont need report if the fax is sent but only print report if the fax is not good(NG or not sent)
it can be set to:
report off--means report will be print out only if the fax is NG
report off+image--means report will be print out if the fax is NG + the image of the page that is not sent(so we know which page is not sent through the image)
report on+image-- every fax activities( sent or not sent) will be reported, which is not recommended
etc....
how to set is depends on your printer, just go to the menu "FAX" and look inside the menu.
Jul 08, 2014 | Epson Workforce 520 All-in-One Color...
How to get a receipt for a sent fax?
Please follow the steps below:
  1. From the Home screen, navigate to Fax Setup. Touch the Setup button.
  2. Go to Fax Setup.
  3. Go to Reports.
  4. Select Print Confirmation Page or Print Activity Logs.
I hope this information has been helpful.
Sep 18, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
Print out confirmation with image on page
press
function
7
monitor key slowly 4 times
set
look on the sheet for confirmation + image parameter
set with above procedure but use number 74
set
Feb 04, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
FAX CONFIRMATION PAGE
Touch ADMINISTRATION then touch CONFIGURATION PAGES then MENUMAP and that will print a guide for you to look for FAX REPORTS and when to print them. You can also have a thumbnail put on a report
Aug 06, 2008 | HP LaserJet M3027x MFP Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax does not print a confirmation page.
Use Function 8 not 6 and use set to lock it in. Lawrence
Nov 09, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
117 people viewed this question
Ben Johnson
