Question about Akai PT4298HD Rear Projection Television
Double picture My Akai PT4298HD Rear Projection tv is show a double image, one pink, one green. Left the room it was fine, when I returned it was as I described
  • daddydan2007 Apr 07, 2008
    not sure if your advice is accurate i will know more once a tech looks at the problem. thanks for the input. i have read more than once this was the problem
    thanx again
  • Akai Master
  • 8,617 Answers
Your convergence ICs need to be replaced. Its an easy job if you can solder. Let me know if you need any more info or a link to where you can order replacement ICs.
Posted on Apr 06, 2008
  • Sonny Berry
    Sonny Berry Apr 07, 2008
    It usually is. Some times its the circuitry that powers the ICs but 95% of the time its the ICs as they run at such high temperatures they are prone to failure on a regular bassis.
Hi ! We just obtained an Akai Projection t.v.
U can't,it ur convergence it dead, must replaced parts.U know how to solders?Tries these websites Ebay.com,Tv repair kits for convergence board or parts.
Nov 14, 2009 | Akai PT4298HD Rear Projection Television
Double vision w/ red & green tint
This is a comon problem
There are two large convergance chip's
the are failing .Replaceing them will
corect the problem . The chip range
in cost from 16,00-30.00 .There cheap,
so dont let the shop over charge you
for parts when and if you decide to
repair it.
Jul 03, 2009 | Akai PT4298HD Rear Projection Television
Akai 42in rear projection TV convergence problem
its the problem of ic on the main board..ic needs to be replaced.not much expensive.
Dec 24, 2008 | Akai PT4298HD Rear Projection Television
PT4298HD Double image
BINGO thats exactly what i get paid to do same price 285.00
Nov 30, 2008 | Akai PT4298HD Rear Projection Television
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Double- Vision
More than likely your akai has defective stk392-040 Convergence chips . it also may have open resistors generally 3.9 ohm flame proff. this board is attached to the top left looking from the back of the set it is screwed on by 1 screw black in the center . after installation this will probably half to be converged dinamically. which means you will half to get to the grid this is done by using the remote press mute 183 quicly to enter numbers on thew remote 2 to adjust red 4 to adjust blue horizonta 6 to adjustred vertical and 8 to adjust red vertical using center button to go up and down
Feb 20, 2008 | Akai PT4298HD Rear Projection Television
Akai
yep you need convergence amp replacment for your set..very common prob call experienced repair person for this job use original replacements....john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
Akai tv
have a good tv guy repace you convergence amp's john
Hourglass shaped red
I need to see a picture of the TV set. send a photo to techman32k@yahoo.com
Jun 05, 2007 | Akai PT4298HD Rear Projection Television
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Akai PT4298HD Rear Projection Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
